Question about Canon imageRUNNER C3220 Printer
Canon Color Imagerunner c3220
The problem i have is that i cannot find where to input the the ip address .
Under system settings
Network
Tcp/Ip
Here all I have are two options SNTP ON ,POLLING INTERVAL&NTP SERVER
  • 1 more comment
  • Anonymous Nov 26, 2008
    I have the same problem and there is no Fiery controller...
  • Anonymous Dec 18, 2008
    Me too.
    We've changed our network around and are now using different subnets.
    The IP address is statically assigned because I can browse to the printers old address even though we have DHCP enabled with a completely different address range.
    In the settings page, I have only a few TCP IP changable settings.
    None of which allows me to change the actual IP address.
  • hardwa May 11, 2010
    Do you have a Fiery print controller (C-2) attached to the back of the copier?
Go to the Printer Tab, select Printer Status/Settings, select Functions, go to page 2, select Run Setup, select Yes, and then you're in like Flynn.
Posted on Jan 15, 2009
I Have a canon imagerunner c3220 it say check TCP/IP Cant get printer to print from computer i previously had it networked and working
First of all, it sounds as if the network cable or plug this cable is plugged into is bad. If they are good, make sure from you IT person what the IP address is supposed to be. You will need to check that the IP address is correct in the copier. Press Additional Functions, then systems settings, then network settings, TCP/IP, then you should see the IP address. Check at the computer to make sure the Port for the printer is the same. Good luck
Jun 13, 2011 | Canon Office Equipment & Supplies
Imagerunner 210S. I have a network card in this used printer but my computer does not see it. How do I install this printer on my home network? Is there an adapter to plug into the ethernet jack to...
  1. You need to set a Static IP address in the printer:
  2. Press the "Additional Functions" key on the Canon Imagerunner 210N keypad.
  3. Tap "System Settings" and enter your administrative ID number and passcode if prompted.
  4. Tap the "Network Settings" button and tap the button next to "TCP/IP Settings."
  5. Press the "IP Settings" button.
  6. Highlight "IP Address" and use the keypad to enter the IP address you want to assign to your Canon Imagerunner 210N.
  7. Fill in the "Subnet Mask" and "Gateway Address" fields with the appropriate information.
  8. Press the "OK" button to save the network settings and enable the new IP address.
Read more: How to Set the IP Address on Canon Imagerunner 210 N ' eHow.com http://www.ehow.com/how_7427700_set-canon-imagerunner-210-n.html#ixzz19ZSyEw8N Then install the driver and poit them to the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 30, 2010 | Computers & Internet
How to install canon 3220 to the network for printing
Hello ,actually its a very easy way to install canon 3220 to a network just download the driver from canon official site :software.canon-Europe.com
go to printers and faxes add printer press local then next choose create port choose stranded tcp/ip write down the same ip of the copier then press next ,choose have disk and specify where the file u download it from the site and after that choose from the menu canon clc3220 c1pcl5 then press ok so now the printer driver is defined. now at the other side (photo copier ) press * system management network settings choose TCP/IP and give the machine IP turn off and the on the machine to save the changes .now the machine is connected through the network :) for more assistant t here is my email mramlawi@gmail.com regards :)
Nov 09, 2010 | Canon imageRUNNER C3220 Color Copier
I'm trying to figure out how to scan a document and send it to email using an IKON (Canon) imagerunner C3220 copier? Is this possible?
The following steps will allow you to send and receive E-mail: 1. Make sure you have all of your TCP/IP information set up (IP address, Subnet Mask, Gateway, DNS Server (if one), Host Name, and Domain name of your Domain) before you begin.
2. Enter into the Network Settings and Select E-mail/I-Fax.
3. If you are setting this up for SMTP (Simple Mail Transport Protocol) to send E-mail and I-Fax, enter the IP address or Fully Qualified Domain Name (FQDN) of your mail server in the SMTP Server section. For example: mail_server.organization.company.com. Then enter the email address that will be the default sender in the SMTP Address field.
4. If you use POP3 and want to receive e- imageRUNNER mail and I-Faxes, fill in the IP address or FQDN of your POP3 server and the account added for the imageRUNNER-iR. The password is optional and needs to be entered if set on the e-mail account of the imageRUNNER-iR. Set the POP interval (how often the machine will log in and check for mail).
5. Reboot the device.
* Note - AUTHENTICATION ISSUES -
-If the SMTP mail server requires authentication for sending email, enter Encryption/Authentication login information (SMTP authentication via a username and password).
- For the models that do not support SMTP authentication, the administrator will need to set up a SMTP Relay.
Apr 14, 2010 | Canon imageRUNNER C3220 Color Copier
Canon imagerunner c3100n Howe do I remove
Your in the copiers IP address into your web browser and go to address book and delete address , you can also add address's here. If you do not know IP address, go to machine, touch additional functions, system settings, network settings, tcp/ip, IP and write down #.
Oct 30, 2009 | Canon imageRunner C3100 Copier
How do i find out the IP address to my Canon Color Imagerunner C33880i?
Description
Since the scope ID had been set under Additional Functions > System Settings > Network Settings > TCP/IP Settings . In the typical network setting
Field Remedy
1. In Additional Functions > System Settings > Network Settings > TCP/IP Settings and press [OK].
2. Turn the main power switch OFF and then ON to restart this machine.
4. Execute the Ping command 60 sec after power-on to check if the host responds it. PLS RATE ME !!!!!!!!THANK U
Sep 23, 2009 | Canon imageRUNNER 400S Copier
Setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Canon imageRUNNER C3220 Printer
Unable to create an email address on a Imagerunner 3220
Hi Keeyan.
Fist you will need a send kit only supplied by your dealer.
If this funcktion is inable follow these steps.
Press the user button(it is the button with the star)
Select system settings,network settings-in network settings go down wit the arrow until you get e-mail/i-fax settings.(If it is not showing here or in tcp/ip settings the send kit might not be enabled)
In e-mail settings enter the smtp server name or ip address(you will find it on your computer in outlook under tools and acounts)
In the email you can enter a email address supplied by your network adminitrator.
If you have a DNS server insert the ip adress of the DNS in TCP/IP settings.
Make sure you IP addres is also correct.
Then you are ready to go
Nov 21, 2008 | Canon imageRUNNER C3220 Color Copier
Canon iR C3220 Control Panel
Hi Ing,
I am not "at" a 3220 but I will try to visualize. On the "op" panel to the right of the display is a button that looks like an asterisk and says additional funcions.Press it. Bottom left tab says "system settings". Press it. New menu,right side , second tab, says network settings. Press it. At that point you should see tcp/ip settings. Press this tab and you will see the ability to manipulate many of your network settings."NOTE" this device is indeed capable of supporting being set to DHCP. You of course understand the pitfalls of having a printer set to dhcp. It is almost always recommended that a printer/scanner/fax/document server/ have a static ip address. However the right IT person in the right network enviromentwill have no trouble at all with this device. hope this helps, and if I did help please let "FIXYA" know it .Good luck and take care. .....................SPINAL........
Mar 12, 2008 | Canon imageRUNNER C3220 Color Copier
Canon iR C3220 Printer TCP/IP settings
Wow,
I am not sure why or how I just bumped into this question 8 months later....and why no one has answered your question prior. I hope to God some one has helped you or you bumped into it on your own. If not, press additional functions,system settings, network settings, and the rest is obvious.
Nov 13, 2007 | Canon imageRUNNER C3220 Printer
Canon imageRUNNER C3220 Printer Logo
741 people viewed this question
old marine
old marine
