Question about Troy Bilt 5.5hp Self Propelled Mower
Repair How can I get a diagramn of assembly to see what part I am missing?
    Problem Solver:
  • 11 Answers
Go to the site of the make that your mower is. theres most likely an online parts list and breakdown with diagrams for you
Posted on Sep 06, 2008
Need deck belt routing diagram
Google make model and belt routing diagramn
Apr 29, 2016 | Garden
Where can i get a wiring diagramn for fraser dragonfly
go to reliable-store. you can easily find your product wiring digram Best Manuals
Feb 11, 2016 | Cars & Trucks
Why doesn't water wring out of clothes
There is a "clutch" that enables the tub to spin but the clutch linings are worn out.
The repair is not too difficult.....I would say that the repair level is about "6" on a "1 to 10" scale.
There is also a possibility that there is a mount that has split into pieces.
Those are the two most likely suspects....
For some reason (I think it was to save money, some Kenmores are actually MISSING one mounting bolt for the gear case / transmission assembly....I looked at mine and I figured that the reason that the mount was broken was because the mechanical assembly was missing the bolt which caused more vibration every time the machine went into a spin.
Jul 15, 2014 | Kenmore Washing Machines
Kenmore dishwasher not draining
There are several reasons why the washer won't drain...
Here are the most probable answers:
1. There is a "clutch" that enables the tub to spin but the clutch linings are worn out.
2. There is also a possibility that there is a mount that has split into pieces.
3. The water pump impeller may not be turning....
4. The drain hose is kinked or not positioned properly (above the level of the water in the machine)....
Jul 14, 2014 | Washing Machines
Image 17.0R incline doesn't work
RUN THE SOFTWARE CALIBRATION FOR TROUBLESHOOTING AND FIX IT. Adjust the speed sensor , clean it, test for open or faulty, and tight the connector very well. see the diagramn attached.
Jan 14, 2013 | Exercise & Fitness
1994 gmc seirra air conditioning compressor wire diagramn
It should be one plug by the pulley and on plug on the back of the compressor,if you replaced the compressor sometimes you have to remove the rear sensor off the old compressor and install it on the new one, hope this helps
Jul 14, 2012 | Heating & Cooling
Dont know where to line up timming/ trying to line up notches. need a diagram
i can explain how to time an engine with no timing marks at all but i dont know or have a diagramn for this engine so if no one answers with a diagramn then get back to me tomorrow and i will explain but it takes me a good 20mins to explain so if you can get a diagramn so much the better
Nov 22, 2010 | 1996 Oldsmobile Achieva
Oil Dipstick
READ THIS THIS IS A LIST OF THINGS THAT CAN CAUSE THIS PROBLEM
ELECTRICAL ROUTINE
Powertrain Control System
· Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, SSA on, transmission range (TR) sensor
· Run On-Board Diagnostics tests. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis.
HYDRAULIC/MECHANICAL ROUTINE
External Shift Linkage
· Damaged, out of adjustment
· Inspect and repair as necessary. Verify linkage adjustment. After repairing linkage, verify that the transmission range (TR) sensor is correctly adjusted.
Incorrect Pressures
· Low line pressure
· Check pressure at line pressure tap. Carry out Line Pressure and Stall Speed Tests. Refer to Special Testing Procedures in this section. If pressure is low, check the following possible components: main control, pump assembly, reverse clutch assembly, low/reverse clutch assembly.
Main Controls
· Bolts out of torque specification
· Adjust bolts to specification.
· Gasket damaged
· Inspect for damage. Repair as necessary.
· 1-2 shift valve, SSA, main regulator valve, low/reverse modulator valve, low/reverse accumulator piston, pressure tap plate damaged, missing, stuck, misassembled
· Separator plates damaged
· Hydraulic passages damaged
Pump Assembly
· Gasket damaged
· Inspect for damage. Install new as necessary.
· Porosity/cross leaks/ball plug missing or leaking, plugged hole
· Install a new pump assembly.
· Pump support seal rings, No. 6 or No. 7, damaged
Reverse Clutch Assembly
· Carry out Air Pressure Test.
· Seals, piston damaged
· Ball check valve damaged
· Friction elements worn, severely damaged or misassembled
· Piston return spring damaged
· Reverse clutch hub to forward/coast/direct hub splines damaged
Low/Reverse Clutch Assembly
· Seals or piston damaged
· Friction elements worn or severely damaged
· Wave springs missing
· Piston bore damaged
Forward/Coast/Direct Clutch Cylinder
· Reverse seal rings damaged, missing, misassembled
Case
· Reverse to low/reverse clutch feeds have severe cross- leakage or porosity
Reverse/Overdrive Gear Set
· Damaged
With all that said, you need to have it taken to either the Ford dealer or transmission shop to pinpoint the exact cause of the problem. Either way, it's likely that the transaxle is going to require removal and disassembly to repair, if the TR sensor isn't the cause. You may print this answer and bring it into the servicing tech, in order to expedidite the diagnosis process. Hope this helps.
Apr 23, 2009 | 1988 Ford Crown Victoria
LCD display missing part of numerals
Yes, we repair these displays for $32.50 with a one-year guarantee. Repair Clinic charges $169.35 for the display board assembly. Tritronics (our supplier) sells the assembly with display (part # DPWBFC167WRKZ) for $107.07. On the rare occasions when we actually replace that type of board for our customer (at our cost of only $73.33) we also perform our proprietary fixes on it. We do that so the new display does not also fail in a few months, or even right out of the box! That actually happens!
Oct 18, 2006 | Sharp R-530ES Microwave Oven
Troy Bilt 5.5hp Self Propelled Mower Logo
97 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Dwain Pippen
Are you a Troy Garden Expert? Answer questions, earn points and help others
