Question about Samson GB-9001 Juice Extractor
WHAT IS THE NAME(S) OF THE TWO ATTACHMENTS THAT SCREW ONTO THE END OF THE SAMSON 6-1? IT'S WHERE THE PULP SQUEEZES OUT OF. I NEED TO ORDER BOTH & DON'T KNOW WHAT-IN-THE-HELL THEY'RE CALLED. THANKS
Look toward the bottom of this page to see the names of the pieces. You're probably referring to a nozzle and the drum cap.
http://www.samsonjuicers.com/parts-list.htm
Posted on Dec 04, 2008
Why is the pulp warm/hot? the screen is clean...
It is caused by friction as the cutter assembly squeezes the pulp out. The tighter the squeeze the more juice that is extracted. Be sure to oil the shaft with only olive or coconut oil as these oils will withstand the high temperature without getting gummy and making the cutter stick to the shaft..
Sep 04, 2014 | Champion Juicers
What is the difference in settings 1, 2, & 3
The higher the pressure the harder the machine squeezes and the dryer the pulp. Leafy Greens and wheatgrass can use Setting "3". Carrots, beets and hard items are best on setting "2"
Jul 22, 2010 | Samson GB-9001 Juice Extractor
Champion Juicer leaking a lot; from screen holder!
I'm having the same problem, the blank screen just doesn't fit the main body that well (I think the body on mine may have been warped by someone putting it in the dishwasher). Since I'm only going to be using my Champion as a front-end for a hydraulic press, I bought some food-grade silicone sealant (from McMaster-Carr or EMI Supply) and I'm just going to permanently attach the blank screen to the juicer body and slide the screen holder over that. There's a new O-ring for the back where the body attaches to the motor that might be needed as well.
May 02, 2010 | Champion 2000+ Household Juice Extractor
How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Jun 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Which attatchment do you use forjuicung
You simply use the Juicing Screen and Juicing Nozzle. The nozzle can be set to "3" for good dry pulp
May 04, 2009 | Samson GB-9001 Juice Extractor
Pulp splattered
Pour some water into it, at the very end.
Jan 06, 2009 | Champion G5NG853S Household Juice...
Cant grt it apart to clean
Take off the top part of the juicer that has the chute. You will see the blade and basket. The blade appears to be attached to the basket with three small screws but is actually screwed onto the basket by a large screw that protrudes out of the basket underneath the blade. So the trick is to unscrew the blade, turning it to the left by using maybe a small screwdriver that you will have to put into one of the two small holes that are on the blade surface and pushing the blade to the left. This should loosen the blade and then you can just unscrew the blade off the basket. Once you get that blade off, the rest of the juicer comes apart. The newer models come with a little tool with a couple of arms that go down into those holes and loosen the top. Good luck.
Jul 22, 2008 | Jack Lalanne Power Juicer (Stainless...
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Jun 22, 2008 | Champion 2000+ Household Juice Extractor
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
Samson GB-9001 Juice Extractor Logo
Top Samson Juicers Experts
eyecam
David Payne
David Payne
Are you a Samson Juicer Expert? Answer questions, earn points and help others
