Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
Filters needed for Old GE Zoneline 2100
Can anyone help locate some filters... They don't have to be new, just in decent shape and usable... Have a few of these models, still run good, however, need filters....
Hello we ahave a zoneline 2100 my ac or fan want turn off even if i turn the ac off 15 rooms ac if need to turn of i have to unplug the ac
Posted on Feb 27, 2009
Dont use Dream Green they cut freon into the air and dont give a **** but the money they make
Posted on Aug 24, 2009
  • 3 Answers
My name is brian pfeiffer . I run a ptac business in griffin ga. I have many parts and filters for most all types of ptac units. Please feel free to contact me at brian@dreamgreenservices.com. Nobody can beat my prices!!!! Or call me at 770-233-9987
Posted on Nov 25, 2008
4 Suggested Answers
ACTECH
  • 80 Answers
SOURCE: I WANT TO BUY THE UNIT WHICH CHANGE HEATING AND COOLING AND TEMPERATURE UNIT FOR GE ZONELINE
WITH ANY OF THESE UNITS YOU CAN WIRE AN EXTERNAL THERMOSTAT WICH WILL ACOMPLISH THIS, JUST MAKE SURE YOU PURCHASE A T-STAT WITH A HEAT / COOL AUTO CHANGE OVER.
Posted on Jan 14, 2008
  • 17 Answers
SOURCE: compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Posted on Feb 10, 2009
heatman101
  • 43501 Answers
SOURCE: hello, i desperately need some
This time I would be looking at the contactor...the contactor coil that creates the magnetic force to pull the contactor in is very susceptible to power surges also...
Follow the power wires back from the fan motor and the compressor and you will find the contactor... check for 24v power going to the coil...I think you will find power going to the coil, but the line voltage will not be going through to the fan motor and compressor.
heatman101
Posted on Aug 27, 2011
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
I have a GE BTB736A100A2. Does the dinosaur have an air filter? If so, then where is it? Thanks.
Hi, if this is a package unit, both heat and air all in one, the filter normally is put in a return vent in the ceiling indoors. If you have a split system, outdoor condenser and indoor blower unit, it may be the same, in your ceiling or on a lower wall near the furnace. It may also be inside of the indoor unit either above or below the blower fan. Depending on the sq. footage, you may have up to 2 or 3 return air filters. If you have looked through out the home, and you don't see any grill, it would have to go in the indoor unit if this is a split. The filter is always located on the return side of the unit, the side that draws air back over the indoor coil. If you can find nothing, you may need to buy some filter media at a hardware store, and try and cut a piece to fit where the air flow is being drawn back into the blower compartment, not the supply air coming in, but going back out where the indoor coil is located to catch all of the dust. Just take your time and look for any register that you can feel air being sucked into, and this is where you can put a filter. If you do find the grill and old filter, it will have the size and a arrow on it and it will go in with the arrow going in the direction of flow, you can feel it. I hope this has given you some direction and help.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
May 31, 2011 | GE Zoneline AZ58H12DAD Air Conditioner
How to change air filters on 2007 Mercedes C230 Sport
I have '05, both should be similar:
1.Cabin air filter is located above battery on right side against firewall.
Release three latches, remove filter housing, slide old filter out (housing is flexible), insert new
one, reinstall housing.
2.Engine air filter is on the left side of the block (follow intake hose). Cover is retained with six screws
(six point star shape,I belive called Torox, bit/scredriver size 25). Loosen screws (don' t pull all the
way out of the cover) lift cover , and remove old filter. Insert new one, reinstall cover. DO NOT
OVERTORQUE SCREWS! Screw holes in plastic filter housing strip very easily.
Note: Intake hose is very flimsy, one on my car came apart and had to be replaced.
Mar 25, 2009 | 2007 Mercedes-Benz C230 Sedan
Slow water flow from GE SmartWater under sink water filter.
I solved the problem! The system's manifold (the plastic base you put the filter in) has small black conical shape button. When you tight the filter in, one of the two small triangle-shaped cams (located close to the filter's central hole) pushes the manifold's button, and this opens the water flow. The problem is that the cams are too low and do not push the button all the way in. Take a pliers and squeeze (not too much!) the cams, so they will raise a little: it will be enough to push the button to open the flow completely.
Mar 11, 2009 | General Electric GE SmartWater Household...
Compressor keep running in off position
Feb 09, 2009 | GE Zoneline AZ55H07D Air Conditioner
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
HVAC
usually the compressor is broken. its inlet valve and the exhause valve sometimes are not as gastighten as before.
if that is true, your room cannot be cooled down.the compressor has to be replaced.
May 28, 2008 | GE Zoneline AZ55H09D Air Conditioner
GE Zoneline 2100 heater/ac won't heat/doesn't shut off
well, it's been almost 4 years since this was posted, but it's the selector knob. these things are HORRIBLY designed (the selector knobs) very easy to break if someone pushes it to the side too hard.
ASSUMING when you cleaned it, you didn't get the controller knob wet, which could cause heat and ac to come on at the same time. If after a few days, it's still the same, it's the selector. I've replaced a million of them (ok, not really a million, but, a lot.)
Jan 22, 2008 | Heating & Cooling
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
680 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
