Question about Dryers
GE Dryer making buzzing noise
When I start the dryer all it does is buzz. This is a GE model # EGD3000B0WW could you please help me.
  • Anonymous Mar 14, 2014
    Frigidaire model#FDE216RES1
  • 1,543 Answers
It does not look like there is an access panel from the back side on this model, but you may be able to try this: Remove power to dryer. Take screw out that holds the end of the exhaust pipe to the back of the dryer and pull out the metal exhaust pipe. Now you should be able to look in and see the end of the motor and the belt. Release the belt and turn the motor shaft by hand. If it turns easily, the drum supports slides are pobably shot ( WE1M333) and possibly the part that holds them (
WE3M26) which causes exsessive drag on the drum. If the motor shaft does not turn easily, hope you have a sock or wash rag stuck in the blower wheel. If not, motor is bad. To get at the blower or the other parts you will have to take the screws out holding the top down to the front of the dryer, then remove the screw on each side near the top holding the front on. Lift the front slightly and remove. You don't have to take off the wires to the door switch. Parts I listed are supporting the drum on the top side. If you need more info do an "ask me" question.
Posted on Sep 03, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
GE Heavy duty Dryer will not start when ''start button'' pushed...will make a loud buzz, starts for anything from 10 -20 seconds if I keep finger on the button then goes off I have to keep returning...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Sep 02, 2010 | GE Dryers
GE dryer, Mod# DDE7209RALWW the timer work when you set it but when you push the button to start it makes a buzzing noise and the drum won't turn. When you let up on the button it stops making the noise.
There can be many reasons why your dryer will not turn...
Here are a couple of tips that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 13, 2010 | GE Dryers
I turn the start knob and it just makes a buzzing sound
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The dryer will not start
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
Buzzing noise when i turn the timer switch
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
627 people viewed this question
Top Dryers Experts
