D52W14 Help Power light blinks 3 times and will not power up... an instructor where I work looked at it and states that the flyback seems to be alright so he is not sure what the problem is.
  • 8,617 Answers
3 blinks is definately the code for the flyback. I would go to the following link and leave them a email and state the model nuber of your set and what the led is doing and they will help you out theyre experts with that chassis. Heres thelink.
http://servicemanuals.vstore.ca/
Posted on Sep 03, 2008
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv d52w14
replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
Jan 17, 2009 | Televison & Video
D52W14 power button blinks 3 times
Yes make sure you get correct flyback,call UED 1-800-648-6657 see if they have part; also are you sure that is what is wrong?Check capacitor cp150 2200uf 16 v see if it is ok or if it is bad this cap if bad will keep set from coming on,and if it is bad there is 2 other capacitors that need to be replaced also.
Dec 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA tv model D52W14
That is an ITC222 chassis and likely the HOT has shorted, 2sc5588 Rca Part # 259899
You might also check Cp150 2200uf/16v in the 6 volt line, a common failure. Always replace Cp120 330uf/35v & Cp150 2200uf/16v and always resolder Cl031 & Cl032...
There is also a tech bulletin Tv-06003 Dated 12/8/2006 which states:
Replace deformed ribbon cable plastic connector BP005 on the flyback board. This connector is warping or bowing (May Not Even Look Like It) and causing poor connections to the ribbon cable. Replace Rca P/N # 258686.
Try putting pressure on the BP005 connector and turn the set on, you may find the set will now work fine. Replace connector and you may wish to replace the ribbon as well while you are doing the repair!
This set is notorious for failures like this and it is not uncommon to find multiple problems.
Hope this helps!
Bill
Aug 08, 2008 | Televison & Video
RCA D52W14 52" rear projection tv
3 blinks means the flyback needs replacing. very easy repair. You can get a flyback at the following link for under 50.00 with free shipping and free tech support so you can install it yourself. You need flyback 259296 here is the link.
Jun 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not power on light blinks 3 times
3 blinks is the code indicating that the flyback is bad. You need flyback 259296 you can get a new one at the following link
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
