Question about Epson Stylus Photo R200 InkJet Printer
Printing problem Hi! My Epson stylus photo 820 will only print the first half of a page. It cuts off and does not continue printing so all documents are only partially printed. I have adjusted the margins, tested the print heads and updated the driver. Any other suggestions? My Epson photo R200 will only print half a photo,i have cleaned the heads and been onto Epson tecnical support but the report came back that my printa was o k but it is clearley not Jenny
  • Anonymous Mar 15, 2009
    I've got the Stylus Photo R200 on XP that only prints the top part of each final page in a run i.e. if its a 2-page document the 1st page prints OK then the last page only prints at the top then just stops and spits out the paper; if its a single page document (test page etc.) it just prints out the Logo and heading then spits it out.
    Tried jiggling, unplugging, re-plugging USB cable to no avail.
    Tried every setting I can find in the properties dialogue - no good.
    Tried uninstall / re-install several times - no good.
    Tried re-downloading drivers from Epson and re-installing - no good.
    Tried installing to my laptop (Win2k) - works perfectly!
    So the problem is with the XP driver but I don't know the solution still.
Try jiggling the cables and making sure that the USB connection is solid. It worked for me. Good luck.
Posted on Nov 08, 2008
How to solve cut out horizontal prints
turn off the printer and pull the plug, so that printer's cache will be wiped then try to print again epson printer ink
Nov 04, 2011 | Epson STYLUS R230 InkJet Photo Printer
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Thanks,
FixerDelta
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson stylus photo rx420
Move envelope/A4 lever near paper output tray until the letter L registers on display. Print in this mode and you should have full page printed.
Jan 21, 2009 | Epson Office Equipment & Supplies
My Epson 1290 only prints half a page
Hello I am use in 1290 printe in epson problem in hafe page print and red led on and printing in hang pl.. uragent in
Thanxx.
Rawat
Nov 10, 2008 | Epson Stylus Photo 1290 InkJet Printer
Printing problem
I uninstalled and reinstalled the printer and now it prints fine, though the paper jammed twice for no apparent reason. Guess it's time for a new printer.
Aug 23, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
279 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
