Question about HP PSC 1610 All-in-One Printer, Scanner, Copier
HP paper jam
I believe that I am having essentially the same problem.
The machine will feed and print if a single sheet is feed into the paper tray - however - if multiple sheets are placed in the tray, it picks up most or the entire trayful of paper and feeds it partway thru and jams or it feeds multiple sheets ahead an inch or 2 and a single sheet completely inside. The single sheet then jams halfway thru and the rollers remain locked making it difficult to remove the sheet.
Any possible solution ? ? ? ? ? ?
  • HP Master
  • 4,338 Answers
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Posted on Oct 01, 2008
  • JDTec
    JDTec Oct 03, 2008
    Did this solution help? Can I be of further assistance?
    P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved.
    • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
    • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
    • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
    • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Tip
Steps to clear paper jam.
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
on Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HOW TO REMOVE BLOCK PAPER
hi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
1. 1 Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Oct 26, 2010 | HP LaserJet 1320 Printer
The paper is jammed. How do i get it out?
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jun 27, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Our Deskjet D4160 had a jam and the paper was pulled out. the paper feed button is blinking and does nothing when we push it. We have restarted the computer, unplugged the printer. What can we do to get it...
hi
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Jul 07, 2010 | HP Deskjet D4160 InkJet Photo Printer
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
6. Step 6
7. Step 7
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
Paper jam in fax how do I clear?
folow the instruction
  • Step 2 Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
  • Step 3 Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
  • Step 4 Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
  • Step 5 Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
  • Step 6 Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
  • Step 7 Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
  • Apr 20, 2010 | HP LaserJet 3055 All-In-One Printer
    My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
    Reinstalling the printer is related the Software.
    If the paper gets physically jammed than its the driver setting issue or hardware issue.
    Check if two sheets get jammed or only one sheet.
    If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
    If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
    If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
    If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
    Jul 01, 2009 | HP LaserJet 1010 Printer
    Hp psc 1315 paper jam
    2.
    3.
    4.
    5.
    6.
    7.
    Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
    Paper feed/jamming problem
    suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
    Mar 23, 2008 | Brother HL-2040 Laser Printer
    676 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
