Shredmaster 1656 makes extreme noise when turned on. Sounds like motor. Please help!
    Genius:
  • 2,120 Answers
Sounds like shred blades are bent down into each other.
UNPLUG.
If you can get the top off, you may be able to use a large screw driver to straighten out the blades.
Posted on Sep 04, 2008
It is very noisy
if it is noisy, you have to open the shredder and check the gears if still ok.
if they are worn up they will make the noise
Oct 19, 2014 | Quartet gbc ShredMaster 950S Strip-Cut...
Ac fan is making extremely loud noises
Are you referring to the blower motor inside the car? If so, they get leaves in them which puts them out of balance and makes them noisy. Just take out the blower, 3 screws, and clean it. That's the cheap answer. It can be a bad blower motor.
Jul 07, 2014 | 1999 Honda Civic
Extremely annoying humming sound coming from our rinnai RCE-318H gas heater. sounds like a bearing or wheel spinning noise. please help?
The humming you hear is from the gas pressure or lack there of. Check the inline gas shut off valve, to make sure it's fully open. If that checks out OK, turn the unit OFF completely and wait five minutes, before turning everything back ON and relighting the heater. If the noise is still there, contact your Rinnai dealer for a service call.
I hope this helped you, Arthur. Thanks for choosing FixYa. Cheers!
Aug 27, 2011 | Rinnai Heating & Cooling
GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
May 21, 2010 | Quartet gbc 2230S Shredder
Taking the top off a Shredmaster cc55
They hide some screws pretty good. Also, try with a putty knife to gently pry arouond the cover seam. Their is always a puzzel to keep end users from DIY.
Jun 19, 2009 | Quartet gbc CC55 (Cross-Cut) Shredder
Focus GRINDING NOISE during excellaration
I had the same exact problem with my 2003 Focus with 108,000 on it. Making right turns and accelerating was even worse. Had many ideas from differant mechanics saying it was wheel bearing, steering rack, loose heat shields, transmission...ect. Well after having wheel bearing replaced and steering rack replaced, the grinding was still there. It was finally discovered that the noise was coming from a bad motor mount on the right side. Had the dealer replace the motor motor mount and finally!!! the problem was solved. Thank God.
Apr 25, 2009 | 2003 Ford Focus
99 Grand Prix Heater only works on 5 makes a Loud noise
hi there
it sounds to me that you have two problems the
loud noise is the heater motor bushings is worn out causing the loud noise and vibration
also you will have to replace the resistor
once the motor is replace and the resistor replace all should be ok
don
Mar 09, 2009 | 2000 Pontiac Grand Prix
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Please Help
We had the same problem at our office. Our machine is also about 1 year old. We checked the warranty and it is covered under a 3 year manufacturer warranty.
The repair person said that the whole motor gave out and they are replaceing it with a new one.
Get it fixed for free.....its still under warranty.....
Hope this helps.
Feb 19, 2008 | Quartet gbc Shredmaster 4550X...
Machine Died?
Hope this helps.
Dec 26, 2007 | Quartet gbc Shredmaster 4550X...
57 people viewed this question
k24674
jasbo
jasbo
