Question about Estate TAWS850PQ
Siezed bearing? My washing machine will fill with water fine but when the cycle begins the basin will not move. The motor seems to be straining and eventually it will trip my circuit breaker. Is there a bearing that could be binding or is there another, more commmon issue?
  • Estate Master
  • 3,361 Answers
There may be something stuck in the pump not allowing the motor to turn or possibly a garment stuck between the tubs.
This video will show you how to remove the cabinet to check the pump and tub. Ignore the part about replacing the drive coupling.
Posted on Apr 07, 2009
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Bowl won't turn or spin. belt is fine but motor doesn't turn. the washing machine begins it's cycle fills with water but once it begins it's washing cycle the dial rotates to safety. The machine will also...
It sounds like you will need a new motor. You pump seems to work and that leads to the motor because it does not spin or move. Motor should be easy to replace good luck
Jan 08, 2011 | Asko W6021 Front Load Washer
WILL NOT AGITATE, SPIN OR DRAIN. WASHER FILLS WITH WATER, HOWEVER, WHEN AGITATOR CYCLE BEGINS, MOTOR HUMS AND BELT WILL NOT MOVE.
Open the back cover and start the washing cycle. When the agitator cycle begins check if the motor rotates. If it does not and the humming sound comes there is problem is withe motor. Also check the tightness of the belt. Even if it is loose it does move but it is slippery movement unless it is completely loose. Anyway the problem is with your motor and the connecting bearing/pulley. You have to ask a technicians to help you out
Sep 29, 2010 | Washing Machines
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
No pressure during wash cycle
Motor pump has gone out. pump needs replacing. the unit needs to be pulled out inorder to access the pump. the sides of the d/w must come off.
Jun 09, 2008 | Dishwashers
check capacitor on motor. possibly not turning at correct speed
Jun 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My gwl 15 ecosmart
having the same problem myself i am replacing the soliniod when it get here. in the mean time the hot water runs in normally so i swapped the hoses over on the back and and now i can wash just that the hot is now the cold button
Dec 04, 2007 | Fisher Paykel EcoSmart GWL15
Estate TAWS850PQ Logo
102 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
