Fix A Burnt Pixel On My LG LCD Computer Monitor Screen, and to also move my actual computer screen back on the mount, its not sitting right-- The Model is LG Flatron 22" LCD Wide Monitor L226-WU-PF
    President:
  • 2,961 Answers
Use this site to try to revive the dead pixel, the main screen should just swivel on the mount
Posted on Sep 03, 2008
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
How can you fix dead pixel?
FIXING DEAD PIXELS These WEB site gives instruction on removing dead pixels, but there is no guarantee it will work except replacing the LCD screen.
http://komku.blogspot.com.au/2008/03/dead-pixel-on-your-laptop-screen-how-to.html
Nov 27, 2012 | Computers & Internet
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
I cannt find driver for monitor LG L1953S
Actually, you should be able to use the monitor without installing a driver. If it isn't recognized automatically, just set the resolution to 1280*1024 pixel and set the screen refresh rate to 60Hz:
In Windows XP right-click on the desktop, open the Properties dialog, select Settings and set the screen resolution. Click Advanced, select the Monitor tab and set the screen refresh rate. If the proper resolution was not available in the first dialog, uncheck "Hide modes that this monitor cannot display" and try again.
That being said, there is a "driver" package, also containing a color profile, available from LG here.
If this doesn't help, describe your problem in detail, let us know your operating system and which which monitor you are currently using.
Mar 20, 2010 | LG L1953S - flat panel display - TFT - 19"...
My screen develops some ghost images after powered up for a few hours. I can actually see some words that appear almost burnt into a screen. Similar to a monitor that has been left on too long if someone...
well you are correct and when it come's with the lcd monitors it is known that when a pixel is subjected to same amount of charge for a long time it might retain the residue of charge even after the amount is changed so this reason why you get this problem and in order tackle this just try to use some changing screen savers or just turn the monitor switch off while you are not around it.
good luck.
Jan 06, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
I can see the correct screen only when i power on the screen, for 1 second
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 14, 2009 | LG L1932TQ LCD Monitor
Dead pixel
Well you have two options, endure it or take it back/destroy it/sell it. No one can fix a burnt out pixel at home. Not even sure that they do at the factory. Pretty sure they recycle the screen and replace it. If you have a burnt pixel, you're stuck with it.
Jun 30, 2009 | Acer X223WBD Monitor
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Jun 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor
Sylvia,
It's seems you had a stuck pixal... Turn your monitor off and try this tips: Wn't work in every case. It may take a few attempts to make sure you are pressing exactly on the dead pixel.These instructions will fix "stuck" pixels, not "dead" ones, like red, blue or green. An alternative, but similar technique involves gently massaging the stuck pixel with a warm damp soft cloth.Alternative technique to tapping: Using a rounded pencil eraser, push with moderate pressure into screen at stuck pixel.
Good lucks!
May 12, 2008 | LG Flatron 295LM 22" LCD Monitor
Regarding L1515S 15" LCD Monitor Resolution
Hello mallik, The LCD monitor is actually a active matrix of small transistors (3 for each pixel). They have one native resolution, a FIXED one for example you monitor has 1024 x 768 pixels. This results in 786432 pixels displayed on the screen. Because each pixel is controlled by 3 transistors there will be 2359296 transistors controlling your entire screen. This is a fix number. You can't raise the resolution to 1280 x 1024 because this will require as you can see now... a lot more transistors on the same surface. All you can do is to lower the resolution, in this case 4 pixels (12 transistors) form a larger pixel acording to that lower resolution. The image can look blurry in these situations. THe bottom ideea is that a LCD pannel (more corectly said, TFT (thin transistor film) pannel, has one optimum resolution, it's native one. The higher the better, when choosing one to buy, but you can't raise the resolution over that. You can just lower it. It works different then the normal conventional CRT monitors. Sorry for my bad english as I live in a non english-speaking country. Also if you have anymore questions please post a comment.
Mar 25, 2007 | LG Flatron L1515S 15" LCD Monitor
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
