Question about Microsoft Xbox 360 Console
Power cuts off
The power cuts off after 5mins then you cant open tray or play any games , the power botton flashes ( no red or green lights around power button) all the time then keeps cutting off and restarts ,
    Sergeant:
    Champion:
  • 285 Answers
Might be a faulty power supply mate , when you turn the xbox on observe the power indicator on the power brick.
Green means its okay
Amber means the console is in standby
Red means the Brick has had it.
Try a friends power brick to see if it does the same.
jonno
Posted on Sep 05, 2008
How do you open the tray on the ps3. the power is on and im on the main ps3 menu but when i push button to open it just beeps
There is no tray on the playstation 3. It's slot-loaded drive; meaning it pulls the disks in and spits them out without opening a tray like you see on a desktop PC or a Xbox. If it's just beeping then that usually means there's no disk in there. The best way to check is if you see a blue light beside your red/green power light, then there's a disk in there. If it's just your red/green power light, there's no disk inside.
Feb 28, 2011 | Video Game Consoles & Games
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
Playstation 3 (PS3) Console: i had a power cut whilst playing ps3 , now it wont...
First thing to try is a video reset.
While the PS3 if off (red light solid) hold down the power button until you hear the SECOND beep, quickly release.
Let me know if this works, otherwise we'll try step 2.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Tray won't open flashes centre green. Opened
The center of your Xbox 360 has malfunctioned due to overheating which has caused the tray to have various problems. The solution? Simple! Replace the hard drive or send it in to Microsoft!
Nov 26, 2009 | Microsoft Xbox 360 Console
Power supply light keeps flashing green and problems with tray op
under normal conditios power supply light should be a steady green light not flashing if not power supply is might be bad call (800) 4MY-XBOX
Oct 11, 2009 | Microsoft Xbox 360 Console
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Disc won't eject & stops working
your disc tray is jamming on an intermittent fault and when it does work it is recording each time the eject botton is being pressed so when your watching movies or playing games it tries to eject the disc tray and causes an automatic shutdown it will definately neet proffesionally repaired and should cost about 30-40 pounds and get a guarantee with it bacause these faults can come back to haunt you.
Oct 06, 2008 | Microsoft Xbox 360 Console
Disk wont open or close
well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
Nov 19, 2007 | Microsoft Xbox 360 Console
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
Microsoft Xbox 360 Console Logo
167 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
