Question about Konica Minolta DiMAGE 7 Digital Camera
"No Card" warning appears on the monitor when the IBM Microdrive is loaded.
    Master:
  • 425 Answers
Please wait for a moment until the warning message disappears and the Access lamp extinguishes. The normal operation will resume soon. The start-up time of the IBM Microdrive, until it becomes readable by DiMAGE 7, takes longer than Compact Flash. In the meantime the camera may not detect card existence.
Posted on Sep 15, 2005
What does the card error mean
Can be lots of things. Would have been handy, if you had told what card you are using. Your camera can work with CompactFlash, Microdrive and xD-Picture cards.
If you did not insert the card(s) you are using, correct, or you removed the card in a wrong way, you could have damaged the cardholder, causing an error you probably can't repair yourself. The CF and Microdrive you can remove by pressing the eject button. The xD-Picture card you can remove by pressing in the card, and release it. The card comes out.
Then you could have damaged the file system, by opening the card cover, while the card access lamp was blinking. What ever card was in, the filesystem can be damaged.
Then you can have two cards in, Both, o CF of Microdrive and a xD picture card. Some settings are required for the camera, to know hat card it should use.
If you have an Microdrive, the drive can be damaged, by a magnetic file, or the drive just stopped rotating. A micro drive is actual a miniature spinning hard drive.
First check if the memory card is inserted correct. Eventually, remove it and check all contacts, on the card and in the camera. Then try formatting the card. If you think there could be important pictures on the card, put it in a external card reader and use a recovery program, to see you can recover the pictures on your computer. Programs can be found on the net.
If you can't format the card, check if you have a Microdrive. If so, try to replace that with a CF or xD card.
I hope something is to any use for you.
Next time, please give us some more details. I know you exactly see and know what is not working, but we only can use your description. And only what you give us.
Feb 16, 2014 | Olympus E Cameras
Does DELL Inspiron 6400 has a inbuilt microphone? If it does how to make it work?
I am sorry to say but, the 6400/E1505 does not have an internal mic. You need External. Sorry. Specs only show a MIC connection. I/O Ports IEEE 1394 4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors Flash Memory Slot - Secure Digital (SD) and SD/IO compliant 5-in-1 Combo Card connector - reads MS, MS Pro, SD/SDIO, MMC, xD CD type I/II, & IBM Microdrive through ExpressCard adapter Video: 15-pin monitor connector S-Video: 7-pin mini-DIN connector Audio jacks: Stereo headphones/speakers mini-connector (same as line-out), microphone mini-connector
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 09, 2010 | Dell Inspiron 6400 Notebook
How to eject cards from Axim?
I attached a plastic strip on the back of my MicroDrive. It has a one inch plastic tab on the top and I use that to remove the drive from the slot. I got the strips (they have one sticky side) with another CF card I got somewhere along the way and it works great! Otherwise, I'd probably be looking at using some fine needle nose pliers, a pair of tweezers or just leaving it in forever.
Sep 14, 2005 | Dell Axim X50 Pocket PC
1GB IBM Microdrive
I got my 1gig microdrive last Wed. UPS says my Axim is going to be delivered today. I'll let you know how the microdrive performs as soon as he axim is charged.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Epson 850Z and ibm microdrive
While my epson batteries were charging, I used a set of alkalines, and something similar to that happened to me (had to re-set time a bunch). When I pulled the batteries out, they were warm enough that the little built in test strip (a thermal lcd) was 'lit up'. It could be a battery load problem.
Sep 13, 2005 | Epson PhotoPC 850Z Digital Camera
Is the Axim compatible with IBM 1 Gig MicroDrive? As this is the only way to put full length feature film onto the PocketPC platform. I know that the Axim has a type II Flashcard slot but want to make...
The advanced Axim appears to work fine with the 1GB Microdrive. Just appears as a "CF Card". MP3's etc play fine from it with no noticeable problems.
Microdrive compatible?
The microdrive is compatable with anything that supports reading compact flash memory cards, because there is a common method of communication between flash and hard drives that use pcmcia or CF slots.
Microdrive
The E-20N power supply circuitry is designed differently from the power supply circuitry of the E-10, enabling it to work with the IBM Microdrive.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
IBM Microdrive
Yes, the E-20N digital camera can use a type 1 or type 2 Compact Flash and the IBM Microdrive.
Konica Minolta DiMAGE 7 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
