Question about Kenwood Car Audio & Video
My kenwood radio keeps going into protect mode ive tried everthing i can think of an notin will work
  • damo mino Sep 04, 2008
    i disconnected all the speakers and amps from the reciever box reset the unit an its still in protect mode!!!!! i put in everthing myself i had the exact same install but wit a different radio and never had any trouble wit it so its been in the car about 2 years problem free!!!! then bought the kenwood and wont work at all!!!!
    i rewired the whole lot re-crimped everthing cleaned the earths and replaced all the wire that had gone bad replaced all the fuses wit the manufacturer spec fuses and even had the unit sent back to kenwood to be fixed but no joy in gettin it back workin!!!!
    Master:
  • 726 Answers
What did u try?
let me no and ill help u further
did u install your self?
or install any speakers?
or amps?
Posted on Sep 04, 2008
How do i take my Kenwood car stereo out of protect mode ?
There may be an internal short which will have to be repaired before the radio can be used.
May 25, 2016 | Kenwood Car Audio & Video
Kenwood KDC-MP342U turns on but just keeps saying "reading" when in usb mode. I recently had it go into protect mode and I took the stereo out and checked the wires and re-attached the ones that...
it sounds like the USB connector on the face place of the radio has a cracked solder joint. i suggest taking it to a person that know how to solder small objects. your Kenwood has a one year manufacturer warranty it could be some thing to check in to.
Jun 18, 2011 | Car Audio & Video
I am installing a kenwood cd receiver kdc-mp205 every thing is hooked up but the screen says protect wat is the problem?
Hello.. sorry to hear you are having problems. With the Kenwood car stereos, when they detect a bad speaker in the car, they go into protect mode to keep from burning up the outputs of the stereo. Either you have a bad speaker in the car or a speaker wire that is touching metal (grounded out). You can cut all of the speaker wires loose at the radio and reset the radio. Then turn the radio on and hook each speaker up one at a time until it goes into protect and that will let you know where your problem is located. Hope this helps and good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 14, 2011 | Car Audio & Video
I have a kenwood it says,kdc-mp142 and all of a sudden it just says protect. it wont do anything
The Kenwood radio will generally give a "PROTECT" error if the amp or receiver is being overloaded. This may mean that some of your wiring may have gotten frayed, one of your speakers isn't putting out the right voltage, or the receiver has decided to go bad. Make sure all of your connections in the back of the radio are solid and not frayed. If that's not the problem, try running each of the speakers one at a time. If one causes the radio to go into protect mode, that's your culprit.
If neither of these are the issue and the radio decides to stay in "protect" mode, your receiver may have seen better days and may need a replacement.
Feb 28, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
MY KDC-MP3342U SUDDENLY STOPPED WORKING! IT JUST KEEPS FLASHING ...'PROTECT'! REPEATEDLY! HELP!
Protect only comes on when an RCA is grounding out, speaker is blown or the speaker wires are shorting out. Check all your wiring on the head unit and see if all are insulated with tape or better and if there's an exposed wire, tape it up. Make sure that all connections are secured. Then double-check your fuses. Check all of your speakers and their wiring because going into protect mode is the units way of saying you have a problem with your speakers or wiring.
If your speakers and wiring all check out, disconnect your radio wiring harness, and then reconnect the harness. This resets your radio, and your radio should be working again.
If you need to enter the security code, try the default unlock code of 5227.
You can also try to reset your code if the default doesn't work. Try 'KCAR' or '3051'.
Jul 12, 2010 | Kenwood Car Audio & Video
My kenwood kvt 514 is in protect mode
It sounds like your amp is not grounded properly and is tryin to use your radio as a ground through the RCA's or there is a bad channel (dead short) in the amp.
Jun 02, 2009 | Car Audio & Video
Kdc-mp2032 how do i get it out of protect mode
Check your speaker connections, you've got a short. Check for loose tape on any connection. Fairly common problem. If your unit is Code Protected.. Try entering the code first, If you have a code, keep it handy, any time you jump start or loose power to the radio, it needs to be re entered before it will work again. Hope this helps
Jun 02, 2009 | Kenwood KDC-MP2032 CD Player
Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Feb 03, 2009 | Kenwood KDC-MP228 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car Audio & Video Logo
120 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
