Question about Saeco Vienna Espresso Machine
Thanks for the reply :)
Mirran,
I should have described it better: I have a solid red light and it is not dead. It will heat water, the grinder will not turn on though...I assume it locked up when the earing was in there and now I have to figure out how to unlock the grinder, any more ideas?
thanks!
  • 515 Answers
It could be the grinder or power board that is the problem, if it was my machine i should replace the grinder.
Try to set power to the grinder, look at the grinder to make sure what volt it should have before you by a new. If the grinder start when you power it then i think your power board must be replaced.
Let me know if i can help you more.
Best regards
/Mirran
Posted on Sep 04, 2008
My xbox 360 get 3 SOLID NOT FLASHING red lights on the face of it... what do I do? 3 SOLID RED LIGHTS NOT 3 FLASHING RED LIGHTS
I CAN FIX IT! There are links that show you how to repair this issue yourself (but they are not very clear and every thing is very fragile inside the XBOX 360) or you can contact me via reply on here and we can discuss the issue further as I recently repaired my XBOX 360 with the same issues and it works better than when was brand new. It is a heat sync problem that has to be repaired by someone with indepth electronics knowledge. THERE ARE OTHER EASIER ISSUE TO REPAIR I JUST NEED MORE SPECIFICS AS TO PROBLEMS EXPERIENCED. try this link as well http://www.zimbio.com/Xbox+360/articles/332/One+Light+Two+Lights+Three+Lights+More
Sep 28, 2010 | Microsoft Xbox 360 Console
Looking for a way to unjam my grinder
If you look at the grinder parts you will see a little red mark, take the parts you lift off the grinder and put it back, turn it clockwise to the red mark is align. You have to press the adjustment pin to turn the grinder parts.
Have a nice day
/Mirran
Oct 26, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco easy
Hi Andrew,
Sorry for the delay, i´m on sick-list and have not access to computer regulary.
Make sure you not get any damp into the grinder.
Try to grind little more coarse to see if the machine will grind the beans.
Have a nice day
/Mirran
Oct 17, 2008 | Saeco Easy Espresso Machine
Saeco Incanto Classic - Bean feed problem
Hi Zlatko,
Ok, i get wrong answer to you. I did a mistake with the model:-(
Yes, you have only one screw in the beanhopper, and to get this cleand you have to take off the top.
This grinder you have to turn anticlockwise to the claque is free you can take it out and clean.
When you put it back you have to turn it so the red mark is together.
If you make a cup of coffe and it grind but not take in water then you have to mount a resistance on the power board.
What serial number do you have on the machine?
/Mirran
Sep 03, 2008 | Saeco Incanto Classic Espresso Machine
Grinder blocked on coffee machine
Can you hear the grinder grind or is it dead?
/Mirran
Saeco vienna Deluxe grinder doesn't work properly
Try to open the steam knob and make a cup of water.
Make sure everything is in place.
One more thing you can try is:
open the door, take out the brewing unit, driptray and dregsbox.
Look in the machine and you will see three hole, one in the lower left corner, one in the middle above the driving shaft and one in the right upper corner.
Turn on the machine and put a screwdriver in each hole and see if the lights go off.
Hope this will help you.
/Mirran
Sep 02, 2008 | Saeco Vienna De Luxe Espresso Machine
Problem with the grinder on my Saeco Vienna
Are the machine dead?
If so, then i think the fuse has to be replaced.
Take off the top and look inside, do you have a round boiler then you have to reset the thermostat on the boiler (two), if you not have a round boiler then you find a fuse on a wire.
/Mirran
Sep 02, 2008 | Saeco Vienna Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
/Mirran
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Grinder will not shut off
I think there are problems with the micro switch inside the machine, if this not work properly then the grinder will go for a while and after that will it signal red.
/Mirran
Jul 23, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Espresso Machine Logo
117 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
