Question about AEG 23 in. Favorit 86070Vi Built-In Dishwasher
The cupboard next to dishwasher becomes full of condensation during drying cycle
18 months ago we had an AEG 86070Vi integrated dishwasher installed in the kitchen. It was positioned underneath the stainless steel sink drainer with an adjoining cupboard to the left which was located underneath the sink itself. During the drying cycle there is a significant amount of heat created which a) makes the stainless steel drainer scorching hot to touch and b) the adjoining cupboard becomes full of condensation. An engineer came out on two occasions and could not provide an answer to why it was happening. The installation is fine and there is no obvious reason why the condensation is forming other than the dishwasher is producing too much heat through the top.
Do you have any suggestions?
Is the machine properly lined up?
Could be a small leak at the top - won't leak water, but steam can escape maybe.
Posted on Nov 20, 2008
Aeg favorit 86070 vi fully integrated dishwasher started bleeping with 3 short bleeps 2 months ago. I followed instructions internet and shook dishwasher to one side and it worked for about 8 weeks. Now...
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Sep 09, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
Not drying dishes, help!!
The LG LDFx810 dishwasher energy saving series uses a condensing system mounted in the door and does not turn on the heating element during the drying cycle. Rather it heats the final rinse water and then runs the condensing fan system to remove the moist air. Energy saving dishwashers will never dry as completely as the energy hogs of 10 years ago - especially the plastic items.
Also, confirm that the rinse aid is full. This will help with drying considerably.
Aug 03, 2009 | LG LDF9810ST Built-in Dishwasher
Frigidaire FDB1050REM2 Stainless steel
They weren't lyin', with the new improved energy effeciency and cleaning units they using more "soaking" times to losen food particles to use less water and clean better. And that they deffinitly do versus old units and they save more energy by doing this also. On some makes and models theywill have cycles that still use less time but also will then use some more water during this cycle. My SEARS store "blue crew" did research and found out this cycle for me.
May 22, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
AEG dishwasher code i30
Its just needs drying out at teh bottom, but check what caused the leaks in the fiirst , make sure you turn the power off
Nov 20, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
AEG 23 in. Favorit 86070Vi Built-In Dishwasher Logo
596 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
