Question about Spherex Xbox 5.1 Surround Sound System Computer Speakers
FIBER OPTIC IM MISSING MY FIBER OPTIC LINE DO I NEED IT
You don't need it, but you probably want it if you have an xbox adapter with a digital/optical connection. They are pretty inexpensive particularly if purchased online. Here is an example:
http://www.iunitek.com/iunitek/index.cfm?fuseaction=shop.dspSpecs&part=2885066
Posted on Nov 30, 2008
  • 1 more comment
  • lingenfr Jan 05, 2014
    Obviously the link above is no longer available. If you want to see the type of adapter I was talking about, do a search on X08-25261 and you will see the M$ Xbox Advanced AV Cable.
  • MeAndMe
    MeAndMe May 31, 2014
    You obviousely didn't read the title to this question. It's about the "OUTPUT" optical line that goes to the Spherex Xbox 5.1 Sound System. Not to the TV. READ, before you answer someones question.
  • MeAndMe
    Your answer is not even related to the question in the title. The person was wanting to know if they need the "OUTPUT" optical line that goes from the Xbox unit to the Spherex Xbox 5.1 Sound System. READ the question and understand it before you answer.
    New Friend:
  • 3 Answers
To answer your question correctly.
Yes, you need the optical OUTPUT cable that goes from the Xbox to the Spherex Xbox 5.1 Sound System. It is a bidirectional optical cable that is needed. Most computer electronics and music electronics supply companies carry the bidirectinal optical cable.
Posted on May 31, 2014
  • lingenfr May 31, 2014
    Wow, you probably need to dial it back sport. First, there are a number of ways to connect, optical is just one, so you don't need it. My answer was correct, but after 6 years, I expect the original poster's Spherex like mine, is in the box in the garage. You can be smart, without being a douche.
SOURCE:
Fiber optic plug does not connect
Optical fiber connectors need to be clean in order to work properly, they need some special cleaning tools, you have to ask for them at the electronic store, normally you should avoid disconnecting and reconnecting fiber optic connectors a lot.
Apr 05, 2014 | Samsung HT-Q100 System
Tip
What is fiber optic connectors ?
The fiber optic connectors is the removable (active) device connected between the fiber optical cables, make the two optical fiber end face precision to dock, so that the output light energy of transmitter optical cable can be maximize coupling to the receiving fiber cable. And make sure its impact can be minimized because of its involvement in the optical link system , which is the basic requirements for fiber optic connectors. To a certain extent, fiber optic connectors also affected the reliability and the performance of fiber optical transmission systems.
Fiber optic connector according to the different transmission media can be divided into common silicon-based optical fiber single-mode and multimode connectors, as well as other issues such as plastic and as the transmission medium of optical fiber connector; connector structure can be divided into: FC,SC, ST, LC, D4, DIN, MU, the MT and so on . The ST connector is usually used to the end of wiring devices, such asfiber optic patch panels, optical transceiver; SC and MT connector typically used for network equipment side. Fiber end shape in the FC, PC (including SPC or UPC) and APC; divided by the number of the fiber core as well as single and multi-core(such as MT-RJ) points. Fiber optic connectors are widely used variety. In practical applications, we generally in accordance with the different structure of the fiber optic connector to be distinguished.
on Mar 30, 2012 | Computers & Internet
Bose Lifestyle AV 28 Media Center and PS 28 need Cable Pin In/Out
Are u talking about the fiber optic cable in and out put of the system all u new is to buy a optic cable if u need a converter from optic to RCA here is the site to buy one on amazon Digital Coaxial Optical to Analog RCA Audio Converter Fiber Optic Cable New 6_26_2014_11_28_58_pm.png
Nov 12, 2013 | Audio Players & Recorders
The in steering wheel cruise control doe's not light up. What fuse is it for replacement?
its a fiber optic line. No fuse. The fiber optic plainly fell out of its slot to beam the light through the white lettering for your cruise control buttons
Feb 06, 2010 | 2006 Chrysler Pacifica
Fiber-optic networking
Apply load balancing of the NIC interface, else put in a switch to interconnect all the computers. That should give equal speeds to all the PC's.....sodeep
Apr 06, 2009 | Computers & Internet
How many fiber optic closures are needed in a 375 km fiber cable?
it depends on the drum length; if your drum length is 4km then you need 94 closure,
thanks
Nasr Kutkut
nasr@kutkut.com
Jan 06, 2009 | 3M Cable Assembly, Fiber Optic Duplex...
Fiber cable running through a steam tunnel
use UTP cable to replace a fiber cable
Dec 05, 2008 | Seicor Fiber Optic Cable
Fiber module
you can login though the console cable, switch back side conso;e port will be there, it will bw like RJ 45 port
May 10, 2008 | 3Com SuperStack 3 4400 (3C17204-US)...
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Spherex Xbox 5.1 Surround Sound System Computer Speakers Logo
186 people viewed this question
Top Spherex Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Spherex Audio Player and Recorder Expert? Answer questions, earn points and help others
