Question about HP Photosmart R707 Digital Camera
Menory card unreadable etc.
Message on camera suddenly reads CARD UNREADABLE and press ok to format card on doing this further message reads CARD LOCKED and to press OK to format it but it wont let me Why has this suddenly happened? My HP R707 just recently started doing the same thing, I can load the images on the computer and clear the card off and it will work again - it does this on 3 different cards I have, so it's not the memory cards causing the problem.
  • Enigma3173 Oct 13, 2008
    Me too. I bought 2 new cards different brands and different memory
  • robinken318 Oct 19, 2008
    I have the same problem, card unreadable or Card has wrong format press OK. No buttons will work for this.
Ok check the card slot for the memory card the pins are bent... for shore
Posted on Oct 22, 2008
When I insert my sd card into my camera it says memory card inserted please change to internal ram.. What will I do?
I think you may mean it says 'no memory card inserted...'etc. but most cameras don't need to say this when there really is no card in place - if there is any internal memory they just switch to it automatically. Perhaps the garbled message is because the card is recognised but unreadable so you might like to try formatting it, either by using the (camera's) menus, or by right clicking the card's icon in the My Computer page (on PC), to bring up the format option
Dec 15, 2010 | Cameras
My hp photosmart r707 gives me a message (card is unreadable) i have inserted a new card and i get the same message each time.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
One thing you could try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible. However, I would expect the camera to report that the card needed formatting rather than that it was unreadable, if formatting was the only problem.
Nov 03, 2010 | HP Photosmart R707 Digital Camera
I just bought a new memory card and tried to format it and I get an error message filesys 001 I think. Bev Caproitti bcaproitti@cox.net
Your camera is only supporting SD/MMC Cards (up to 1GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Dec 28, 2009 | Kodak EasyShare C330 Digital Camera
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
Card is unreadable
Take out the card and transfer the photos to the computer. After you verify that your photos are safely on the computer, reinsert your card in the camera and proceed with the formating.
Aug 03, 2009 | HP Photosmart R707 Digital Camera
Locked card, that isnt locked.
Hi Try useing SDCARD FORMATTER V1.2 . This prog is put out by PANSONIC. i have used it to resuce quite a lotof sd cards.
Good Luck.
Douggie11
Apr 27, 2008 | HP Photosmart R727 Digital Camera
Memory card problem with motorola v360
Try to format it via a memory card reader by your computer. Good luck!
Sep 13, 2007 | Canon PowerShot A95 Digital Camera
"Disk is unreadable" message when inserting a CF Card - Macintosh OS 9.x
Certain system software is needed to allow a Macintosh (running Macintosh OS 9.x or earlier) to access mounted compact flash cards. If this required software is not installed the computer will not be able to recognize the card and will display the following error: DO NOT press the "Initialize" button, as this will completely erase the card and destroy all images. Click the "Eject" button and then enable the necessary system software. The following Extensions or Control Panels need to be activated: File Exchange - Control Panel Foreign File Access - Extension The "Extensions Manager" Control Panel (found under the "Apple" menu) can be used to enable these items. After switching them "On" restart the computer to apply the changes. After restarting the computer insert the card and it will mount on the desktop like any removable disk.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
HP Photosmart R707 Digital Camera Logo
325 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
