Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Convergence I remplace r7013 and ic7001 it burn r7013 again it is possible that the didital convergence module is working bad
  • 2,335 Answers
If the digital convergence module is defective, it will not cause R7013 to burnt again. I would suggest to check the solder joints on pins # 12, 13 and 14 to make sure there isn't any solder bridging causing the new resistor to burn.
Let me know if you need further assistance.
Posted on Sep 03, 2008
  • Jaime Hernandez Sep 03, 2008
    The pins to check for bridging are 12, 13 and 14 of IC7001.
My virago 250 burning the rectifiers
Hi, Luleenea the first thing I would do is check the integrity of the rectifier ground wire also for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
ViragoTechForum com
keep burning out my regulator rectifier Anyone know why
https://virago250street.files.wordpress.com/2013/10/yamaha_xv250_service_manual-lit-11616-xv-25-1994-291-pgs.pdf
OEM parts for Yamaha
https://virago250street.files.wordpress.com/2013/10/2002_virago_250_owners_manual-lit-11626-15-02-2001-98-pgs.pdf
Jun 05, 2012 | Yamaha Virago 250 Motorcycles
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Have a rear projection tv 55pp9352. Has green halos around objects on the screen. Checked convergence and all red and blue line up except that on the outside edges the convergence crosses are somewhat...
yes, you need remplace the liquid in the picture tube green and blue, and need remplace 2 parties stk-392-120 and resistences 6.8 ohms at 1/2 watts
Jan 05, 2010 | Televison & Video
Replacing STK Modules in a Panasonic Rear Projection HDTV
Hi there.
If you look up the datasheets for the 392 series, you'd find more differences than power and voltage ratings... Using a similar IC (even if it is the same series) may make it difficult, if not impossible, to converge. It's recommended to change the 2 ICs as a matched pair. Since one already is failing or failed, the other probably isn't too far away.
The resistors mentioned are to bias each output stage for proper deflection and must be within tolerance. They're precision blue flameproofs, so if anything really heated up from a bad IC you'd easily catch any browning / burning. Red is IC7001, blue IC7002, and green is split between the two ICs.
Tha advantage getting a factory supplied or authorized distributor part is you know the LOT NUMBER has been approved by the manufacturer. Generics or unusually cheap originals are often rejects from the manufacturer as being out of tolerance.
The originals are only $29 each directly from Panasonic. Why go through all the effort tearing the thing apart twice to save $30?
Good luck, Mark
Nov 28, 2008 | Panasonic PT-53WX42 53" Rear Projection...
PT53WX54J Shut Off LED blinks 3 times
3 blinks LED shows problem with convergence out ICs that either bad or not getting supplied volts from supply board to function properly.
Sep 08, 2008 | Panasonic PT-53X54 53" Rear Projection...
Colours not mixig together
you can get the new ic's at this sight i will post and free online tech support and they will also tell you the exact value of the resistors because when those resistors burn its because your ic's are no good I have used this service many times and the techs will go the distance to help people
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Samsung HCN436W 43" Rear Projection...
Samsung TV model HCN5527W
The actual Convergence amp ICs not located on the convergence board are probaly what killed the origional convergence module, and likewise has killed the new board. You will need to change the convergence ICs first then replace the convergence module.
I would recommend getting the service manual . I can post a link if you would like.
Mar 17, 2008 | Televison & Video
Panasonic 47wx42f projection
Joe,
It sounds like your may need to replaced your convergence ic's loc# ic7001 and ic7002 stk392-110. That should take care of your alignment problem.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence off on PT-47WX49E
If it's really bad and happened all at once, your convergence amps have failed would need to be replaced before you could correct the issue with an adjustment.
May 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
