Question about Sony Computers & Internet
I can not get a internet connection either wireless on cable but with cable it connects to ip address but not internet?
    Champion:
  • 200 Answers
What kind of security programs you have?
if its (Mcafee or norton) and its expired make sure that u remove them and run the removal tool also.
second thing go to start
run
type cmd and hit ok
type these commands:
ipconfig /flushdns
ipconfig /renew
netsh winsock reset
netsh firewall reset
now reboot the computer and tell me what happened with u
cheers
Posted on Sep 03, 2008
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
Tip
Internet Connection Basics
Modern high-speed internet connections are made using DSL or cable modems. In general, most DSL modems also act as routers, but not too many cable modems act like a router.
Some internet connection basics: Every device connected to the internet has an IP (Internet Protocol) address. The address consists of 4 groups of up to 3 numbers each. They would look like this: 123.111.36.145 (0 is the smallest number and 255 is the largest you will see). When you connect to the internet, you are assigned an IP address by your ISP (Internet Service Provider). When you hook up your computer
to the modem, the signal is passed through the device to your computer and the device's IP address becomes your address. This is not secure, as the "bad guys" could type your IP address into their machine and theoretically see your computer and access all your data.
Connecting with your modem: Modems come with a CD nowadays. Running the setup CD makes connecting quite easy. With a DSL modem, you normally have to provide a username and password to log on. Cable modems generally rely on the cable connection to your house to recognize who you are and when you run the setup CD, you are automatically connected.
The router: The purpose of this device is twofold--one is to take the signal you get from your ISP and send it to a number of computers in your home network. The second purpose is to take the IP address and send it to a different address on each computer. This acts as a "firewall" in that the IP address assigned to your computer is no longer the address of the computer. Those bad guys trying to hack into your system will have a much more difficult time.
Types of routers: There are wired routers capable only of hooking up computers with ethernet cable within a network. There are wireless routers--normally these have 4 wired ports and a set of antennas. These function will in a mixed environment of wired and wireless computers. Most people these days are using wireless routers.
In my next tip, I'll describe how you go about hooking up your new router to an existing internet connection.
on Aug 09, 2010 | Computers & Internet
Not providing valid IP addresses
make sure that your router is acting like a DHCP server.
also make sure that your pc's ip is set to "obtain automatically" under local area connection->properties->internet protocol->properties
Jan 25, 2010 | D-Link DSL-G624M (0790069285783) Wireless...
How do i setup my internet on the samsung nc10? i am wirelessly connected but when i go into networks it says te local connection is not connected because the network cable is unplugged but i dont have a...
Local area connection is meant for wired LAN connection. you can connect the internet using a straight clable wire.
on how to make a straight cable,below is the link
http://www.ertyu.org/steven_nikkel/ethernetcables.html
But as you have said you can connect using wireless,then in wireless adapter setting,
Assigned your IP address Plus Subnet Mask address.
Set your wireless access point IP address as your Default Gateway Address.
In Primary DNS address as provided by your Internet service provider.specify secondary address too,it available.
If DHCP server is available then you don't need to configure anything.
If you are trying to browse internet through a proxy server than Go to internet Explorer,Click "Tools", Select "Internet options ", Select Connection, Tick Proxy server and specify the IP address of your proxy server and the port.
you will be able to browse Internet now.
Rate this answer.
Dec 27, 2009 | Samsung NC10-14ROBL Notebook
DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
May 24, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Don't know what an ipaddress is
An IP address is an Internet Protocol address. Essentially it's like your mailing address, but for the Internet. It's a unique address that identifies a specific Internet connection (not necessarily a particular machine, however).
For online gaming, your IP address is how the online part of the game can talk to your individual game console.
Having an IP address requires having an Internet connection. Normally if you have a broadband connection, your IP address is assigned to your cable or DSL modem, which may then assign a private internal IP address to its clients (your PC, your game console, etc).
Depending on your game console and how it communicates with the Internet.
http://en.wikipedia.org/wiki/IP_address
Some additional information would be good...
  • What kind of connection to the Internet do you have?
    Cable, DSL, something else?
  • What game console do you have?
  • How does your PC connect to the Internet? Is there a box it is connected to, or does it use wireless?
Apr 07, 2008 | Video Game Consoles & Games
Help connecting Cable Internet through D-Link DI-514 Router
what may be happening is the wireless pc as it was; needs the dns and ip address flushing, also the pc you connected the router to as you must have conflicting ip addreses Click start run then type ipconfig /flushdns. You should ensure that the router is set to enable DHCP to assign ip addreses and make sure your'e network cards on all pc's are set to obtain ip address automaticaly in the TCP/IP properties. Restart the pcs and type 192.168.0.1 in your web browser and get into your router setings and check in the DHCP section that all pc's have been given an ip address. If all fails you may need to reset the router
Sep 03, 2007 | D-Link DI 514 Wireless Router (DI-514)
Wpn 824 wireless issues.
if you have set up the wireless connection and enable it in the router, i assume you have disconnected the wired RJ45 cable to the pc, if not do so, as the pc's ip address is still being sent to the wired adapter and needs to be giving the wireless adapter an ip address itself as you cannot have two. Either remove cable or dissable the wired network card and ensure you enabled DHCP in the router settings to automatically give the pc an ip address, ensuring that thw wireless card is also set to obtain an ip address automatically in the TCP/IP properties of the wireless network adapter.
Jun 21, 2007 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
