Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidare dishwasher Help! My frigidare gallery ultra quiet 3 is smoking during the drying cycle. The house nearly burned down. Is there a recall on this product?
    Sergeant:
  • 409 Answers
Can you give me the exact model # on your dishwasher and i will check for you.
Posted on Sep 13, 2008
My frigidaire gallery ultra quiet III dishwasher does not spray water within the barrel case; is my surge pump gone?
Yes Yourr Pressure pump that does teh high pressure spray is not working. Now identify the wires to the pump and check the voltage during the cycle .If present the pump is faulty and must be replace. However if there is continuity on the coild ccheck to see that a reset can make it work from a strck up condition.
If there is no voltage on the pump the controller unit is faulty.check relay , check board..
Sep 17, 2010 | Dishwashers
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
May 20, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Dishwasher not cleaning the dishes
Hi there. Here are some solutions that may help you combat this issue with the non cleaning of the dishes during the wash.
• Choose another cycle for longer washing
time.
• Check rack loading section for proper
loading—avoid nesting items.
• Home water pressure may be too low—
should be 20 to 120 pounds per square inch
(psi).
• Check incoming water temperature. It
should be at least 120°F (49°C). (See
Factors Affecting Performance.)
• Check water hardness. For extremely hard
water, it may be necessary to install a water
softener. (See Detergent Chart.)
• Use fresh detergent.
• Check to make sure funnel in top rack is not
blocked.
• Make sure items are not blocking the spray
arms, preventing them from rotating.
• Check to see if the rinse aid dispenser
needs refilling.
Next, you mentioned in your text that you were experiencing a burning scent after the was or during it. i have a few solutions for that as well.
• Soiled dishes left in dishwasher too long can
create an odor. Use Rinse & Hold cycle.
• There will be a "new" smell when first
installed. This is normal.
• Check to see if unit is draining properly.
One more thing, sometimes food or plastic dishware will fall between the spaces in the basket that holds the dishes. these plastics can be burned by the heating element inducing a burning scent during the drying process. always make sure that all plastics are secure before you start the cycle. food can get stuck on this heater element as well causing a burned smell.
Feb 15, 2009 | Dishwashers
have you cleaned the fliter in the bottom
Feb 15, 2009 | Frigidare FGB24S5DC Gas Single Oven
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
601 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
