Question about Panasonic Lumix DMC-TZ3 Digital Camera
Screen reads..."Mode dial is not in the proper position"
Nothing I have done solves this problem... eg recharge battery, select various mode settings, laying of hands ; ), etc.etc. No buttom pushing has remedied the problem.
I had the same problem, so bought a few precision screwdrivers and took the back off. Be careful, but you can release the top section and on the bottom of the dial is a few plastic spacers which had squashed. I straightened these out, carefully put it back together, and this solved it. I think these spacers hold the electronin dial in place, hence why it comes up with " not in proper position ". If you fancy trying, it only took me 5 minutes and I know nothing about electronics.
Tom A
Posted on Oct 17, 2008
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
Nikon Coolpix S8100 and when I turn it on it says Mode Dial is not in proper position
Return the camera right away, it is clear this is a manufacture defect, nothing more can be done.
Mar 22, 2012 | Nikon S8100 Digital Camera
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
I have a Nikon D3100 and surprisingly the dial mode does not work properly. I mean when I turn it, at some modes, it shows the selected mode correctly on the display, but not for all
Hello mehran_vafae, is supposed to have put a DX lens.
The mode dial, select in what way is going to take a picture.
You can make combinations according to the mode set in the mode dial, with the Fn key / command dial, command dial / aperture A mode, command dial / shutter speed S mode, Full Auto / + / - compensation sw, etc. ..
Please carefully read the user manual supplied with your camera and if it fails take them to Nikon service.
Regards
Mar 21, 2011 | Nikon Cameras
How to use flash on a vivitar vivicam 8690
Look on the Mode Dial find a small icon looks like a camera, rotate the Mode Dial to select.Toggle the flash settings. Look on the Mode Dial and find a small icon that looks like a camera, then rotate the Mode Dial to select this setting. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Mar 17, 2010 | Cameras
"not allowed to dial"on f003 phone
hi mate,just follow these instructions 1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive(can take 3 to 15 min) press the end button (red one) phones with one middle button use that one phone will go off turn on phone and it will be reset to flight mode....(you can try to make call to verify,phone wil say cannot make call,not, not allowed to dial like before) go to settings and network setup,sim1 network setup,prefered mode and select gsm prefered...(phone will now change mode unlike before saying unfinnished) try the phone to make a call (should be no prob now) not finnished though .... go into settings again select restore factory settings (password 1122) wait for phone to restart...now its all done .....now you can change your tones and turn wlan on etc do not for any reason select wlan only or gsm only again...
Jul 19, 2009 | Dual Electronics CECT P168 Cellular Phone
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
CAMERA WILL NOT TURN ON
Try new good quality batteries.
i experienced this issue last night. Even after replacing the batteries i had the same problem though the batteries were from a very cheap pack & i'd had them a while. The camera worked fine once i'd recharged my normal batteries. I'm no expert but I expect switching the camera on must use much more power then review mode causing the camera to switch off before it has time to tell you your batteries are low.
Hope this solves your problem!
Sep 03, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
The LCD image is dark or nothing appears on the LCD screen.
The camera may have shut off automatically. Press the shutter button halfway down or turn the camera Off and then back On to View or Play mode. Make sure the lens cover is removed. Check your batteries and make sure they are installed correctly. Recharge or replace the batteries if necessary. Make sure the dial is set to LCD mode.
Sep 12, 2005 | Epson PhotoPC 3100Z Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
252 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
