Question about Sony KP-57WS500 57" Rear Projection Television
Sony KP-57WS500 TV shuts off. LED flashes 8 times.
  • ladywinn
    ladywinn May 11, 2010
    You said tv shuts off does it try to come on then shut off? It is also very possible you have a defective Tube R/G/B i have replaced a few. You also have a little blue capacitor located right behind hori output Transistor look to see if it is burnt,or has small hole on side of it.1200pf 2Kvs
  • 10,594 Answers
8 times flashes shows error in D board and T8005 Fly-back Transformer, Horizontal Output Transistors, and many more critical parts can be defective / suspected. If you need D board part number, please let me know.
Posted on Sep 03, 2008
  • 2,322 Answers
The flyback transformer is defective when the LED flashes 8 times. The FBT is located on the main board(D board).
Location of the part is T8005 and the Sony part number is 1-453-285-41
This part is available from this website.
This type of repair might not be a DIY due to the danger of working with devices that generate high voltages.
2 Suggested Answers
  • 3 Answers
SOURCE: sony kp-57ws500
Before you trash your set or spend$$$$$$ try this link
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Mar 07, 2009
How do fix my 5 inch sony the light flashes 8 times
Prior to this were you getting a bright red, green, or blue screen with trace lines?
Apr 03, 2012 | Sony KP-57WS500 57" Rear Projection...
If you follow the info from this website, you will be able to fix your TV.
Use at your own risk. Please be very careful when working around devices that generate high voltage is excess of 32.5Kv.
Oct 28, 2008 | Sony KP-57WS500 57" Rear Projection...
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection Television
THE LED ON THE FRONT OF THE SET SHOULD BE BLINKING IN A SERIES OF BLINKS THEN PAUSE AND REPEAT THE SEQUENCE. IN ANY CASE IT NEEDS TO BE SERVICED BY A SONY AUTHORIZED SERVICER.
Dec 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Our Sony KV36FV16 works perfectly for 5 min. then powers off.
After speaking to a local TV repairman, the concern of labor and unavailability of parts, led us to purchase a new TV!
Dec 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Blue screen flashes and the tv shuts off
You will need a service manual you can get one here it could be the tube, video or numerous things. Your service manual is available at the following link. Plus online support
http://servicemanuals.vstore.ca/
Jan 07, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
345 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
