Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Help!!! It won't start.
I have a shop-vac quiet wet/dry vac. I have not had any problems with it until today. I turned it on and nothing happened. I changed outlets and checked my extension cord, it wasn't them. I can't afford a new one so can anyone help?
  • kelzak Sep 04, 2008
    THANKS, I'LL GIVE YOUR SUGGESTIONS A TRY WITH GRATITUDE............KELZAK
  • happyhus Feb 21, 2009
    I have a similar problem except mine shut off while I was using it. So could it still be the switch?
  • 706 Answers
When you say you checked your extension cord, what do you mean by that? Were you able to ohm out the wires to determine that you didn't have an inline break anywhere? Just because you changed outlets to a known good outlet, doesn't rule out a problem with the cord, switch or motor itself. If you have access to an ohm meter, volt meter, continuity checker or even an inductive power sensor ( electritians use these all the time to find live power feeds) then you may be able to determine where the problem lies.. I did a cursory search for a wiring diagram for that particular model but was unable to locate one. Not having that information means I am only speculating what your problem could be. Is there a reset button or popout circuit breaker on that model that may have tripped? If so, reset it and try it again. If not then you may need to do some troubleshooting of the hardware itself. Not sure I've helped you at all but I tried.. Hope you can trace out the problem... Good luck..
Posted on Sep 04, 2008
  • Rick Gelin
    Rick Gelin Sep 04, 2008
    It shouldn't be too difficult to find the problem if you have some test equipment.. I hope it's just a simple inline break in the cord that you can work around.. Good luck my friend !
Mini shop vac
There is a hidden thermo fuse in the tape on one of the field windings. If it overheats that fuse will blow and the motor won't run until replaced.
May 22, 2013 | Shop Vac 925-13 Canister Wet/Dry Vacuum
The paper filter on the Shop Vac locking ring won't stay on, how do I fix this?
It has to be pushed all the way on to where the plastic is solid. It's usually quite hard.
Apr 13, 2013 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
My shop vac blows dust as soon as it's turned on and throughout use. I have changed filters, nothing is helping. What part of my vac can not get wet, or is there a better way to clean out the system?
there should be a cover or sock over the filter,this will stop the dust.the paper filter is the part that can not get wet. if you don't have a cover for your filter use an old sock or something simular to a sock.
Aug 04, 2009 | Shop Vac 584-04-00 Quiet Canister Wet/Dry...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Set up the shop vac to pick up water
I figured I had nothing to lose so I just started vacuuming. I thought I had to turn the end of the hose that connects to the shop-vac around (which I did so that it brought the water down to the 'bucket'. Other than that, I even went to Yahoo Answers and asked for input. The answers were - just vacuum, they didnt think there was anything to do with the vacuum to set it up for wet vac. I had removed the cloth filter used for dry vacuuming so I was ok with that. I also saw a YouTube video that said basically to remove the cloth filter. Ok .... that was not so difficult. Thank goodness too.
Jul 26, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
After i cleaned the filter, shop vac doesn't turn back on
IT SOUND LIKE THE MOTOR WENT BAD OR IN SIDE THE PANLE A WIRE CAME LOSE
May 04, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shopvac 2010
Just be sure to remove the paper filter bag that fits over the foam filter before vacuuming liquids. It's easy to get it wet and they don't work very well when that happens.
Dec 10, 2007 | Shop Vac 201-13 Wet/Dry Vacuum
Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Nov 05, 2007 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
906 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
