Question about Boss Car Audio & Video
My Boss Amp keeps cuts off when I play the music from my stereo
  • 52 Answers
Check your ground wire and your remote wire, Wiggle them separately both at the amp and at the ground point. See if it cuts out then, and you;ll know which one. Also, does it have a light on it when it cuts out? if so, it could be going into protect mode, which wont allow it to turn on for a period of tine. Make sure the amp is not too small for the speakers you are pushing.
NGK
Posted on Sep 03, 2008
How do I connect my Boss CE-5 pedal for stereo?
Quite simply connect each output to its own guitar amp or use two mono or one stereo DI box and connect to stereo PA.
Sep 25, 2014 | Roland Boss CE-5 Chorus Ensemble CE5...
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
I have a Boss 4x50watt in-dash stereo, 2 Pioneer 270-watt max/ 40 watt nominal rear speakers, and 2 Pioneer 500 watt peak/ 80 watt rms front speakers. Do I need to buy an amplifier? Or is does the head...
You do not need to buy an amp, the only reason to buy one is if you do not think it is loud enough when you turn up the volume to max. The speakers you have can take more power than your stereo can provide, but you only need to add an amp to get more power if you want it to play louder than it does now.
Dec 19, 2013 | BOSS AUDIO SYSTEMS Car Audio & Video
How to format my sd card to play video on my boss bv8962
i had the same problem. It is illegal to watch videos while driving hence why they dont tell you how to play youtube off of card and usb. But after hours of testing converted videos here what works for me.
download pazera free flv to avi converter. after that you will have to custom convert the videos with these settings....video format is MPG custom MPEG-2/ FPS 29.97. Audio mp3-mpeg- layer 3/ bit rate 128 and i added stereo-2 for kicks. last but not least custom resolution 720x480. convert and it works :)
Dec 16, 2012 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
I have a Fender G-DEC Guitar amp and it has an output for recording, can I connect it to the BOSS MICRO guitar input? The Fender amp has many rhythm functions which I am very familar with, besides it has...
you can use the line in/mic stereo input, but you will have to turn the input level way down to around 1 or 2.
i assume that the record outputd a re rca outs. you can get a rca stereo to 1/8 inch stereo adapter, like the ones they use to connect protable cd palyers to recievers, and then get a 1/8 inch stereo to 1/4 inch stereo adapter form radio shack to complete the connection.
Aug 15, 2010 | Boss Micro BR Digital Recorder
My usb car stereo dosnt play all the songs on my kingston
Not every car stereo can play every song in a usb.
This deppends on how many songs and how many folders you have in your USB, regardless of the USB's capacity. My car stereo for example, can only play about 50 songs pero folder and i think it tops at 9 folders.
Try to organize your music in folders and change the names of the songs taking every "·$&%/&$/)(=)(( Symbol and non regular character out.
Or better, get your car's manual and it might say how many songs it can play. i think mine cant read over 1.5gb. if it doesnt say, you just have to try and work with it till you get it figured out.
The last thing i try and it might work:
Cut everything out of your USB, format it and then paste everything back this refreshes the USB and sometimes it works.
Sorry about my english.
Sep 25, 2009 | iLO XM-MP3-CD Car Stereo
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
My Boss Amp keeps cuts off when I play the music from my stereo when i play music and turn it up the amp keeps cutting in and out and i have to tap it and it will turn on
someting is busted in the amp! needs to be repaired or replaced !
make sure all wires are tight tied to the terminals first!
thanks
erik
Feb 24, 2009 | Car Audio & Video
When i play music loud the sound cuts out
i would try getting a new amp, the speakers may be blown.
Dec 30, 2008 | Audio Players & Recorders
Car Audio & Video Logo
225 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
