Question about HP PhotoSmart 7260 InkJet Printer
Cradle Jam, Mechanism error
Whenever I give print command, the cartridge cradle is stuck at the right hand corner, paper is half drawn,red light flashes and an error message appears as"cradle jam,mechanism error" and can't print. For last two years, it was giving me trouble free service.I am using Windows XP3, original HP 57 and 56/58 ink cartridges.The loacal HP authorised technician failed and returned me the same after two months.I am an retired Electrical Engineer and if proper guidance be given,hope I will be able to rectify it.
  • lorri4624 Dec 30, 2008
    I have same problem. Cradle used to move to the center when top cover was opened to replace ink cartridges, now it does not even do that. Why can't someone design a printer that lasts longer than 2-3 years??
All Office
  • 58 Answers
SOURCE: Mechanism Error - Print Cradle won't move! - HP 5650
This "plastic strip" is called the "carriage encoder strip". This strip dictates the timing of the carriage assembly. If the end slots aren't broken, you can re-attach it. Otherwise, you'll need to replace it. They are about $10.
Posted on Jul 03, 2007
SOURCE: cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Posted on Dec 31, 2007
SOURCE: The cradle is stuck
Fixed it myself...found this link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00738923&dlc=en&product=443024
It would print the Tap Test as instructed in this illustration....but then wouldn't move to print anything else. So redid the Tap Test several times....then I lifted the lid while printing a test page so the cartridge was in the center and I could get ahold of it to slide it....left the printer ON, but unplugged the power cable...and then I was able to move the cartridge back and forth. I then took QTips with Windex on them and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
A couple more test prints...and sliding the cartridge......and it is finally running again.
Posted on Jul 08, 2008
SOURCE: print cartridge cradle stuck
There seems to be a problem with the cradle not "lifting" itself up and over what appears to be some sort of guide. Rock the cradle gently back by hand (it will only move a few millimeters) and move it all the way to the right into its bay. Cycle the printer power and it should be fine.
Posted on Oct 02, 2008
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Posted on Dec 30, 2008
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Same or similar problem
Try to download the updated driver for this printer, I have the same problem and solved with the newest driver.
Jul 10, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer cradle jam
I have a hp photosmart 5500 that had the same symptoms. I am no expert, but the first thing I did was unplug the power and UBS cord. while the cradle door is open, you can see that there are three mechanisms that push up to the cartridges from the bottom. On my printer, those were mis-aligned. I was able to remove each of the 56, 57 & 58 cartridges with some effort without breaking any of the hardware (but it was difficult. Somehow, I was able to push the set of mechanisms back down into their lowest position, put the cartridges back into place, and then plugged both cords back in. This seemed to do the trick. Be careful to have a bottle of nail polish remover handy to clean up all the ink that you will get on your fingers or screwdrivers that you will use to push the mechanism back into place. Have it ready beforehand!!!
Feb 08, 2018 | HP PhotoSmart 7260 InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
Mar 03, 2008 | HP PhotoSmart 7260 InkJet Printer
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Cartridge cradle is stuck
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
HP PhotoSmart 7260 InkJet Printer Logo
Ben Johnson
