Question about GE GSS25JFM Side by Side Refrigerator
GE model # GSS25JFMC WW
Help! We had to remove the doors on this Refrigertor during a move. The right dorr is nt allingning correctly, it's about a 1/4 in to high. Is there a diagram on line showing all hinge parts? or can you email me one?. my email is Phone 281-326-5431 Thanks, Tony Pape
  • rmizzell Nov 29, 2008
    What would cause the water to stop flowing to the water dispenser in the freezer door..
  • Anonymous Jan 21, 2009
    Water dispensor would quit and then work again but now it has been days and is still not working
The comprossor stays off and the fan is runing
what can be the problem?
Posted on Aug 17, 2009
No water from dispenser, i found blockage at the dispenser (frozen water) i used string trimmer, insert thru the dispenser and use a hair dyer also. Move it in and out and heat the string. You will feel it cold, in 5 mins you will have water.
Posted on Mar 05, 2010
  • 57 Answers
Parts for this model (and others) can be found by clicking >>>HERE<<<.
Type in the model number ... and magically - by the force of the internet, your parts breakdown will appear!
Another article on this model can be found by clicking >>>HERE<<<
which relates to door alignment and frost problems.
Remember to click "FixYa" below if this solves your problem!
Posted on Apr 15, 2009
    Problem Solver:
Freezer is starting to defrost and the seal around the door is extremely hot.
Posted on Jul 13, 2009
Evaporator fan not working ge profile pss26mgpa ww
Try spinning the evaporator fan motor with your fingers. If the freezer door was left closd it may have rusted on its shaft and be stuck. We need to test the voltage going to fan if oiling its bearing and spinning byhand does not get it moving. Click Here for a service manual=> HERE and here=> GE Artica Test Sheet The fan motor or a relay on the motherboad may also be defective. You should get 12-13 volts DC at the fan motor, Thanks Sea Breeze
WR60X10185 Evaporator Fan Motor
Dec 10, 2012 | GE Profile Arctica 25.4 Cubic Feet...
Defrost heater mnot completely defrosting
unplug it and get your hair dryer remove the panel again and blow dry the entire thing untill all is melted be carefull not to over do ad not to put dryer in the freezer stand back where the water will not splash on the dryer after leave it off for 1 hour than turn back on and put setting on number 3 for 2 to 3 hours than adjust to your normal setting not higher than 5 or it will repeat problem.It is getting very well cool causing to over cool to fast.
also air spray out back side and bottom of refrigerator is always a big help
Good Luck
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
My ge side by side model gss25jfmc ww will start to freeze food in the cool side then it stops cooling in the freezer side. Ice will form on the back wall of the freezer. I haved thawed it out &...
I can tell you how to find the problem , but , it is a little work .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , and , when to cycle off due to temp satisfied .
Jan 01, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #: GSS25JFMC WW. during the pass two days my refrigerator has stopped cooling.
Your refrigerator has a control board on the back. This is likely the problem. Another possible problem is the start relay and capacitor on the compressor. To examine the board unplug refrigerator and remove cover over the board. Remove so you can examine both sides for burn marks or signs of heat on the black relays. Visit my site and enter the model or part number into the search feature You will also see a picture of this board on my web page.
Board part number WR55X10656 main control board. Thanks, Sea Breeze
Jun 30, 2009 | GE GSS25LGM Side by Side Refrigerator
check to see if the fan at the compressor is running
Jun 17, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE GSS25JFM Side by Side Refrigerator Logo
1,877 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
