Question about Zenith IQC50H95W 50" Rear Projection Television
Red bulb went to **** on me and i know how to replace it but where can i get one?
Well i got my 50in tv for fre cuz the guy said the red bulb went to ****. well it is and the guy that had it before told me he put paper over the bulb and the picture is fine but just no orange red and other shades of course. im sure its the whole bulb but any other ideas of what else may be wrong and where to get parts for it? thanks.
  • sandmannc Sep 04, 2008
    i thought zenith was purchased by another company?
    i live in wisconsin in the usa. i really appreciate the help. this is making my life alot easier
    Master:
  • 726 Answers
It will be the bulb there roughly 230 dollars u can order though the make of your tv
Posted on Sep 04, 2008
  • chris07551 Sep 04, 2008
    were abouts are u like country ill have a look were u can order them from exact price and if they dilver or pick up
    ok ill look around now for u ill let u no as soon as i no wont be to long
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
I had been getting the bulb life low message so after it went completly went out i replaced the bulb. my tv was absolutely fine before now it has a red haze on the top of the screen and it was not staying...
Power supply for a red haze problem? Doesn't sound like a powersupply issue. If its a red haze that Im thinking aobut, you might as well buy a new set. It'll be a little too costly to fix.
When it was shutting down, what was the red light blinking before it paused then repeated?
Dec 29, 2009 | Sony KDF-50E2000 50" HDTV
I have an LG 50in 1080p Plasma tv. We turn it on
Many of these unuits were recalled to have the power boards replaced, the 42" model was a class action court case . The reason your set worked after sitting for 2 days was because unplugging and leaving a for several hours was equivalent to a hard reset. Try doing that before you submit for repair again. It will probably fix it temporarily again.
The power boards were made in China and have been faulty workmanship. Try laying a claim against LG even though you are out of warranty. I would as they know this problem existed with many of the models they flooded onto the market.I would never buy an LG product again
Pleadee rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Televison & Video
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
I have a 50in hitachi rear projection tv that has a approx. 30 in red circle in the center that dominates the color what can i do . im very mechanical inclined or is this something that i will have to take...
this is the optical assy if you can get the polarizer filter you could replace those.if not call hitachi 800 line they might authorize a new (rebuilt) engine
Mar 03, 2009 | Televison & Video
I have a RCA 50in DLPModel #M50wh74s
Two possibiltes. A bad cooling fan or what is known as a color wheel. is this a whining sound. does the colors flicker. a bad fan could have contribited to the bulb going out too. to identify a technician would have to take back of and examine fans and listen
Dec 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
The TV screen just went blank!!!!
usually the lamp light blinking red is an indication that the lamp has malfunctioned. Try removing the lamp housing and reinsertng it. if that doesnt help you will need a new lamp or ballast. most likely the lamp
Mar 26, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
ERROR CODE 34 on Mitsubishi TV
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Feb 16, 2008 | Televison & Video
No picture, just went off while watching tv
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Nov 06, 2007 | Toshiba 51H84 51" Rear Projection...
Zenith IQC50H95W 50" Rear Projection Television Logo
281 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
