Kenmore HE2 jsrock- I saw your detailed explanation of cleaning the drain pump for duet machines and kenmore elite: http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet Will this same check work on a kenmore HE2? My washer sounds like there are rocks in it only when the drain pump is moving (not when washing or spinning only). thanks, PJ
  • 5,911 Answers
Yes, it will. There are two screws holding the bottom panel in place that you will need to remove first. Your pump may be constructed differently than the full size HE models. If you do not have a clean out trap, unplug the washer and remove the pump. Flush it with water to clean out the impeller. DO NOT submerge the motor portion in water, however. If you have to remove the pump, just disconnect the electrical connections and the inlet and drain hoses. DO NOT remove the hose from the bottom of the wash tub. Disconnect all hoses from the pump only. In my past experience, this particular hose is a real bear to get back on. You may not have to do all this. I include these instructions, however, because some of the small front loaders do not have a clean out trap on the drain pump. I hope this helps you. Let me know if you have further questions.
Posted on Sep 03, 2008
Error 5d: Remove bottom panel. Unscrew large white pvc looking trap. Removed 25 coins, several small stones and my wedding ring! Large dollar coins here in canada so tlhere was considerable amount of stuff. No problem after that. And i got my several year missing wedding ring.
Posted on Feb 28, 2012
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
I keep getting error code F21 on my kenmore elite which is a drain error the drain is not clogged and the drain hose is not clogged any ideas on what I could do?
The error code F21 is similar to F02 which both pertains to a draining problem. The usual cause is a blocked drain filter or a clogged/kinked. But since those areas are found to be not the source of the problem, the problem must be somewhere else. It is either the drain pump is broken particularly the impeller if the pump just hums/whirs or the pressure switch contacts are stuck/welded together and is, therefore, not tripping. The link below provides the detailed troubleshooting instructions the problem of this kind after the drain filter has been cleaned out.
Error Code F02/F21 on Whirlpool Duet and Kenmore Elite Front Load Washers (Filter Cleaned)
Aug 21, 2011 | Kenmore Washing Machines
There is a code of 5d
The following link explains the error in more detail and how to correct: http://www.fixya.com/support/r3608687-sud_error
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code can be generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
COURTESY:jsrock - A senior expert of fixya...
Jul 11, 2011 | Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
CODE F-21 NOT SPINNING THE WATER OUT when it comes to the rinse cycle . IT MAKES A CLICK SOUND AND STOPS . THEN IT SHOWS CODE F-21
The machine is not spinning the water out because there's a problem with the drain system as the error code indicates. Either the drain hose is clogged or kinked, the pump filter is blocked, the pump impeller is blocked or damaged or the pump itself is not working at all. The click sound may due to a blocked pump impeller.
Disconnect power and the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 31, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite, HE3t, front loading washer, Model 110.45972404. Constantly shuts down during cycle with SUD or F02 signals. If I pause and restart sometimes it works. However last night it would not drain...
F02 indicates the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
I think the drain pump is clogged due to SUD formation.
COURTESY:jsrock - A senior expert of fixya.....
Jul 08, 2010 | Kenmore Elite 45986 Front Load Washer
Control locked. How do you unlock it?
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Check below link for detailed explanations
http://www.fixya.com/support/r3608801-control_panel_lock
Courtesy JSROCK
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
Controls locked light
Courtesy JSROCK
Mar 31, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F-21
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
Go the below link and it will help you further...It gives detailed explanation By one of out experts JSROCK
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Mar 11, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
254 people viewed this question
Top Washing Machines Experts
