Question about Toshiba PDR-M65 Digital Camera
Choosing batteries
What kind of battery should I use?
    Novelist:
    Scholar:
  • 104 Answers
Your camera requires four AA size batteries.There are several factors that contribute to battery life: NiMH: This is the best solution for enjoyment and cost savings. NiMH batteries typically last longer per charge than the average alkaline batteries. NiMH batteries are rechargeable batteries, so they can be used several times and thereby reduce the expense of continually purchasing new batteries. NiMH batteries are typically sold with a power adapter for charging. The life of these batteries can often be determined by the mAh rating, the higher the mAh rating on the battery, the longer that they will last. NiMH batteries do not have the memory effect associated with NiCd batteries, which means that these batteries can be recharged at any time and at your convenience (you do not have to wait for the batteries to completely drain between charges). Lithium: Energizer has introduced a new series of Lithium batteries that provide optimum performance and long life for disposable AA size batteries. Laboratory studies shows that Lithium batteries last more than three times as long as standard Alkaline batteries. This means many more hours of fun and satisfaction with your digital camera. These lithium batteries are not rechargeable, they are long lasting. Alkaline: Using the LCD display, downloading images, playback, zoom and flash all require some battery power to operate and may decrease the number of shots per set of batteries. Performance may also vary based on the Alkaline batteries selected. To significantly increase battery life, be sure to turn off the LCD when it is not in use. The LCD consumes the most amount of battery power. The benefit of being able to use alkaline batteries is that you can find then almost anywhere if needed. Manganese: If you are using manganese batteries, the typical battery life will be about 2 - 5 shots. Then the camera will indicate that battery power is low and may shut-down. To avoid this experience, use either Alkaline or NiMH batteries. Optimum Solution: Use a set of NiMH batteries for longer use and to reduce the expense of continually buying new batteries. It may also be a good idea to keep a spare set of NiMH batteries for other devices that require AA size batteries on a regular basis. Use AA Alkaline batteries when the NiMH batteries need to be recharged and you want to continue enjoying the use of your camera
Posted on Sep 15, 2005
No connection when trying to charge battery
hello there!
i will help with your problem. just follow these steps.
1. remove the battery and memcard. 2. put it back and make sure that it properly put.3. connect the cable of the charger and charge it.4. make sure that the charger is properly plug in in the socket and in your digi cam.5. if still not charging, try to charge to other power outlet.
if still not working, call a service center or an authorized repair shop and ask them to check your digi cam. there must be a problem inside.
thank you for choosing fixya and kindly rate my post.
Jan 25, 2012 | Olympus STYLUS TOUGH 8010 Digital Camera
Samsung gt-b7320 drains battery charge while charging. why?
hello there!
the battery of your phone is not functioning well. meaning, you have to replace a new battery for your phone.
tip:
don't use the phone while charging. let it be fully charge. and not to overcharge it too. because using the phone while charging will reduce the life span of the battery.
thank you for choosing fixya and kindly rate this post.
Jan 25, 2012 | Samsung Cell Phones
Not starting up
hello there!
so you're phone won't charge up...you should buy a new battery...your old battery is not functioning well...
tip:
don't use the phone while charging. let it be fully charge before using it again. and don't let it to overcharge too. this will reduce the life span of the battery.
Thank you for choosing fixya and kindly rate this post.
Dec 30, 2011 | Sony Ericsson Cell Phones
The tachometer kind of jumps around, always drops then goes back up i dont even know if its right.
have your charging system checked for free at any auto zone or advance auto parts store,your altenator may be going bad, or your battery may not be accepting the charge from the altenator. tach guages going crazy are a sign of bad altenators or bad batterys. hope this helps and thank you for choosing fixya.com
Feb 27, 2011 | Toyota 4Runner Cars & Trucks
My car doesnt start unless i jump start it.
either the battery needs to be replaced or the alternator. generally if the battery has failed and it runs after a boost it would be the alternator.
Jan 09, 2011 | Nissan Quest Cars & Trucks
Battery keeps dying out. I bought the right kind of battery aweek ago and had the alternator replaced 2 times, and it still kills the battery. what would be the cause?
you could possibly have a blown fuseable link in between the altenator and battery.a fuseable link is a hard piece of rubber that has a fuse inside of it. the rubber is an insulator. when you locate it, the rubber will be burnt hard and very dry. it will crack under pressure is one way to check it and you will have several of those links,links to different electrical components. one easy way to check if your altenator is charging is with the engine running, remove the positive cable from battery[ careful not to ground it or let it touch any metal] if car dies,altenator charge is not going to the battery. hope this helps and thank you for choosing fixya.com
Nov 12, 2010 | Pontiac G6 Cars & Trucks
I have a Hitchi Radio/CVD player KC-92CD and I don't know what batteries I need for the remotre
Take out the batteries and check?Very small long tube battery kind?That the AAA kind of bateries.Long tube battery kind?That the AA kind of bateries.Square battery kind?That the 9 Voltage batteries kind.
Oct 21, 2010 | Hitachi Televison & Video
Toshiba A105 Laptop will not come on
Kindly try to remove the battery from the system and connect the system only with the power adapter.
Try to turn on the system. Keep the power button pressed for few seconds.
Please revert with your helpful comments.
Thank you for choosing Fixya
May 27, 2010 | Toshiba Satellite A105 Notebook
Cannot get battery to hook up
Ensure you are choosing the correct connector, there are (2) inside the compartment, one for the battery and the other for the toy. There should only be ONE way to hook it up unless you were choosing wrong cable.
Apr 22, 2010 | Peg Perego John Deere Gator HPX Ride on...
Toshiba PDR-M65 Digital Camera Logo
118 people viewed this question
Top Toshiba Cameras Experts
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Lawrence Oravetz
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
