Question about Creative Labs ZEN V Plus MP3 Player
Not recognised by computer running Vista 32bit machine
Zen V plus 4gb charges fine via USB connection but the unit shows a device error 10 in device manager under portable units. The Zen device is recognised but the icon has an "i" on it.
Any suggestions?
  • Anonymous Sep 05, 2008
    Same problem, mine's only a 2gb but it says error code 10 as well
I have the same problem...
Posted on Sep 04, 2008
My Zen seems to be totally dead after loading it with mp3 tracks. I've recharged it to no avail, it won't switch on or reset, and it is not recognised by my computer when connecting via a USB...
hi your not the only one i got mine for my birthday 8 weeks ago and now it dont work its like its dead this zen v plus to is like not the best thing to have all i see is people like me having some sort of prob with it
Sep 20, 2011 | Creative Labs ZEN V Plus MP3 Player
I have a problem with a Zen PMC 20GB. When I reset the device using the pinhole reset button, the unit goes off and then comes on with the "Creative Logo" and then it goes to a diagram screen...
  1. Turn off your player
  2. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  3. Power on the player
Oct 09, 2008 | Audio Players & Recorders
Zen V Plus not recognized ANYwhere on the computer...don't have original CD, have downloaded the driver update and media explore software which begins to load and fails because the computer cannot find the...
most computers have lots of USB inputs. my frnt USB cords don't work on my MP3 but I plugged it into my back USB port and it work fine...Just try to use other USB ports
Feb 25, 2010 | Creative Labs ZEN V Plus MP3 Player
My PC can't seem to recognise my Creative Zen Vision M 30gb anymore. It has been working fine but today nothing doing. The display on the device says it is docking when I plug into PC but PC says it is not...
What you have to reset is the PC, not the Zen.
Try unplugging the PC AC cord for ten-fifteen minutes. This will drain power and get rid of electrostatic charges accumulating on USB connector contacts.
If that does not work, check USB status in device manager, and test the Zen with a different cable. Also test the unit on a different computer.
Aug 14, 2009 | Creative Labs ZEN Vision:M Digital Media...
Computer wont recognise my zen Vplus
replace or usb cable...f not chek usb port of ur unit
Jun 30, 2009 | Creative Labs ZEN V Plus MP3 Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Zen V Plus not charging and not recognized by windows
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Aug 18, 2008 | Creative Labs Zen Micro MP3 Player
Recogniton problems
Get the Vista compat software. If you already have:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 10, 2008 | Creative Labs ZEN V Plus MP3 Player
Computer doesn't recognize device is plugged in.
try aa different USB Port if your computer Has One.
Turn the power On The MPEG Player on and off when it,s Connected.
If this does,nt help.
Replace your USB lead, it is possibly broken internally, or player fault.
Mike @ Compurepair.
Feb 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v plus 4GB
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Oct 24, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
51 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
