Question about Canon BubbleJet i320 Printer
Every time I try to print and warning comes on Print head not installed. what can I do
  • llchilds1937 Aug 08, 2011
    I cleaned the printer head contacts with a piece of paper and used a q tip to clean the bottom of the printer head with water from the faucet. I also cleaned the printer pins with a q-tip and I still get the same message install printer head. Is there anything else I can do.
    I liked this printer because it was easy to fill the cartridges with a refill kit. Is there another type of printer you would recommend that would be easy for me to refill the cartridges with out damaging the cartridge.
  • Canon Master
  • 11,800 Answers
In this printer the head is separate from the cartridges and in a single block. The cartridges go in it and the block goes in the print head carrier. Because of that in time the connections between the head block and the carrier gets dirty and the heads can no longer communicate and be recognized by the mainboard of the printer.
To clean those contacts remove the cartridges and lift the grey lever that holds the print head block secure in the carrier - the lever goes up from the front and to the rear. Now just tilt the bloc forward and lift it up. With a rough piece of paper wash and clean the contacts at the rear of the block; then take a q-tip and clean the contact pins from the carrier. At the end put all back together and try again.
If the heads are still not recognized then the dirt has corroded the contacts. This is unfixable and because there are no replacement parts it means that the printer is dead. Time for a new one.
Posted on Aug 08, 2011
  • Azrael SRL Aug 08, 2011
    Just one thing left : make sure that the white ribbon cable that connects the carrier to the mainboard is intact and firmly plugged in. If it is then the printer is indeed dead, nothing more can be done to save it.
  • Azrael SRL Aug 09, 2011
    http://www.amazon.com/Canon-iP2600-Inkje...
    refill instructions
    black http://www.refillinstructions.com/Canon/...
    color http://www.refillinstructions.com/Canon/...
SOURCE:
Ip4850 flashes 5 times
According to the Official Canon knowledge base, it means that either print head is not installed at all, not installed correctly or the print head is defective. Install or reinstall the print head or if that doesn't help, replace the print head with a new one...
Also your print head nozzles can be clogged with dry ink, so before changing the print head with a new one, try to clean the print head with some warm water so the dry ink can come out of it... If that is of no help, as I said above - buy a new print head and install it or buy a new printer, if buying a new p. head is too expensive compared to a price of a brand new printer...
Mar 26, 2013 | Canon IP4850 Inkjet Photo Printer
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
Tip
Diagnose Canon Pixma Light Blinking Errors
ORANGE LIGHT FLASHES
2 times - No paper (ASF) [1000]
* No paper in the cassette [1003]
3 times - Paper jam [1300]
* Paper jam in the rear guide [1303]
* Paper jam in the under guide [1304]
* Front door closed [1250]
4 times - No ink [1600]
* Ink tank not installed [1660]
5 times - The print head is not installed [1401]
* Print head temperature sensor [1403]
* Faulty EEPROM data of the print head [1405]
6 times - Inner cover open [1841]
* Inner cover open (while printing) [1846]
* Inner cover open (printing continuous) [1851]; (printing not continuous) [1856]
7 times - Multiple ink tanks of the same color installed [1681]
* Ink tank in wrong position [1680]
8 times - Warning: The waste ink absorber becomes almost full [1700]
9 times - The digital/video camera does not support Camera Direct Printing [2001]
10 times - Automatic duplex printing cannot be performed (paper size not supported) [1310]
11 times - Failed in automatic print head alignment [2500]
13 times - The remaining ink amount unknown [1683]
14 times - Ink tank not recognized [1684]
15 times - Ink tank not recognized [1410 to 1419]
* No Blinking Access cover open [1200]
16 times - Valve sensor [6C00]
ORANGE / GREEN FLASHES
2 times - Carriage [5100]
3 times - Line feed [6000]
4 times - Purge cam sensor [5C00]
5 times - ASF (cam) sensor [5700]
6 times - Internal temperature [5400]
7 times - Waste ink absorber full [5B00]
8 times - Print head temperature rise [5200]
9 times - EEPROM [6800]
11 times - Carriage lift mechanism [5110]
12 times - AP position [6A00]
13 times - Paper feed position [6B00]
14 times - Paper feed cam sensor [6B10]
15 times - USB Host VBUS overcurrent [9000]
17 times - Motor driver [6D00]
18 times - NIC Board [6550]
19 times - Ink tank position sensor [6502]
20 times - Other hardware [6500]
* Alt. Blinking ROM
* Light in Orange RAM
SERVICE MODE
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1. With the printer powered off, hold down the Resume/Cancel button and press the Power button.
2. While holding down the Power button, release the Resume/Cancel button and press the Resume/Cancel button twice in succession. Now release the Power and Resume/Cancel buttons.
3. Select one of the following service mode functions by pressing the Resume/Cancel button the specified number of times.
Count Indicator Functions
• 0 times Green Print head not installed, carriage returns and locks in home position
• 1 time Orange Service test print
• 2 times Green EEPROM information print
• 3 times Orange EEPROM initialization
• 4 times Green Waste ink counter setting
• 5 times Orange Destination setting
• 6 times Green Print head deep cleaning
• 7 times Orange LF correction
• 14 times Green Left margin correction
Execute the selected function (except for model setting) by pressing the Power button. The printer will switch itself off after performing the function.
on Feb 10, 2011 | Office Equipment & Supplies
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Brother mfc210c has media error warning no media is in the slot, and it is telling me to reinsert media.
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 31, 2011 | Brother MFC 210C All-In-One InkJet Printer
Print head is not installed
First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist the print head is defective and you need to replace it.It's part number is QY6-0054.
Nov 02, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Will not print and error message come up.
The print head has failed, or the logic board is faulty. The print head is cheaper. Try replacing that.
Sep 30, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Hello i have a service light on saying print head tempreture,would i need a new print head ,please help thanks
hi,
this service message just warns you that the print head temperature is not normal. just give it some time to get to room temperature and then continue printing. if the problem persists, try troubleshooting the printer or test print to check the condition of the printer.
cheers
Jul 26, 2009 | Epson Stylus Pro 10000CF InkJet Printer
Print head noi installed
Sometime the problem is the cartridge it self....And sometime it's the cartridge beside the one that is always warning.
Mar 25, 2008 | Office Equipment & Supplies
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Canon BubbleJet i320 Printer Logo
256 people viewed this question
Clive
Clive
old marine
old marine
