Question about Kicker ZX10001 Car Audio Amplifier
Won't turn on
I recently bought a zx1000.1 kicker amp but it won't turn on all I hear is a click noise coming from the amp every time I shut off or turn it on.
Any suggestions. Thanks
  • oumatilla Sep 05, 2008
    Thank you for letting me know. How hard is it to fix, if i want to do it myself? and how do i do it.
    Thank you in advance
  • 631 Answers
It sounds like the muting relay is engaging but the power supply isn't working. This is most often caused by blown power supply FETs. There may be other damage.
Do you want to try to repair the amp yourself?
Posted on Sep 05, 2008
  • 4 more comments
  • Perry Babin Sep 07, 2008
    If you're interested in learning to do this type of work, you may be able to repair it but it may take quite a bit of effort. The following page shows you what's generally involved in repairing amplifiers. Read through it to familiarize yourself with the inner workings of an amplifier.
    Basic Amplifier Repair
    If you simply want the amp to be repaired quickly, you should pay to have it repaired.
    Let me know if you have any other questions.
Why won't the fuel pump shut off
Fuel pump won't be the cause. Most likely the relay.
Apr 06, 2017 | 2005 Mazda 6
2004 chrysler pacific will start sometimes but sometimes won't
I would suspect the fuel pump is the problem, it may be sticking at times and this causes a no start. The pump is located inside the fuel tank and it is electric.
Mar 28, 2017 | 2004 Chrysler Pacifica
Kicker zx1000.1 stopped working completely. I have 3 Kicker 10" cv subs hooked to it. The first time it shut off I turned the system off. When I turned it back on it worked for a few minutes and...
First check to see if your'e getting power to the amp by using a test light and touch the main power(12V battery) connector on the amp, test light should come on since it's constant 12v supply. Now turn on the radio and test the remote wire connector on the amp and you should have 12V(test light should come on). Also make sure that you have a good connection with your ground wire, check both connection points to make sure it's good. Now if you have power where your'e suppose to and when your'e suppose to and the amp does not power up, then it may be time for a new amp. Try wiggling the connections at the amp a bit, the solder may be cold/loose.
Jul 12, 2011 | Kicker Car Audio & Video
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
My Amp Keeps shutting off
You need to get an amp with higher wattage. Obviously, your amp cannot handle those two 10" monsters. hehe Nice Subs though :D
May 01, 2009 | Kicker Solo-Baric L7 10'' Car Speaker
My amp turns off when i turn my speakers up
there is a safety feauture in the amp that shuts if off it is getting to much power from cd player outputs. all amps have this. some cd players also have this. unfortunately there is no way to get around this besides turning up the amp and turning down cd player
Mar 31, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker sub wont work
Im guessing that it is possibly blown... either you ran too much power to it, or it was hooked up wrong... you should unscrew the sub from the box and look inside to make sure that it is connected correctly.... positive to positive, negative to negative,,, if they so much as touched then the L7 could very well be blown.... smell the magnet and if you smell a burnt smell... it is blown... maybe turn your amp down a little... its possible that it is also in protect mode because you are running too many watts to the amp. Feel free to ask if you have any other questions.... Please rate! :D And good luck... i really hope its not burnt out. that stuff is not cheap.
Dec 29, 2008 | Kicker Car Audio & Video
Kicker amp troubleshooting
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 01, 2007 | Car Audio & Video
Car Audio & Video Logo
323 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
