Question about Sony Playstation 3 (PS3) Console
Clicking noise whenever i insert a game or dvd the ps3 makes a machine gun clicking noise sound and doesnt load then stops then when i eject the disc it makes the same noise then when it stops i press eject again it ejects, how do i fix this problem it does it about half the time i insert a disc.
  • 344 Answers
The only way to fix it is to open up the disc drive and reset the the mechanism that sets the disc with the laser. As the system draws the disc in, it also raises the laser unit that is hooked to a gear driven mechinism. Sometimes when dropped, kicked, smacked...etc, the gears can come off of alignment. It's a pain to repair but really not that hard. You really need some patience and a to be carefull not to damage anything. Hope this helps.
Posted on Sep 04, 2008
I have an issue with my ps3 slim 250 gb, when i insert a disc into the system it does not load the first time, it makes an odd clicking ejeccted disc sound and will not load. I have to eject and reinsert...
Sounds like you have an issue with the blu ray drive itself. This is actually a more common problem with PS3 than many people know. Do not try to fix this yourself as it will void you warranty. Contact Sony as it should still be under warranty and you will need to ship it away and get it fixed.
May 19, 2011 | Sony Playstation 3 (PS3) Console
Hi I have a ps3 slim and it just recently stopped ejecting my disks.when I press the eject button the ps3 makes a clicking sound but nothing comes out.but if I turn it off then back on it makes the noise...
He is full of **** trying to scam you. It sounds like your disc drive is out of alignment with the top part of the disc drive so the clicking your hearing is the bottom of your disc drive trying to eject and the top is holding its on as the top has sliding parts that meet perfectly with the bottom part of the disc drive so it sucks the game in and out. You need to open it yourself with a philips head screwdriver you dont have to worry about the motherboard or any other part just take the drive out undo the ribbons connect the drive to the motherboard then it should pop right out. Been awhile since I took a slim apart they dont break as often (yet). From here you should have a metal caseing over the disc drive maybe not with the slim. You pop the metal caseing off the you have a plastic disc drive. Take the top part off maybe requires small phillips screw driver. Since you have a disc in it when you take the lid off hook the cables back to the ps3 motherboard and to the cd drive. Now press eject with the top lid off. Then put the top lid back on and insert a disc it should work. Then just put it back together. Theres a little motherboard on that cd drive do not short it out on anything. You can do this if you cant worst is youll have to buy a new cd drive from the repair shop you mentioned. Then they should charge to much labor to put it back together as you had it apart when you got there. But you should beable to do it if you need help taking it apart just google or youtube slim ps3 disc drive repair or how to take apart slim ps3. Hope this helps if not let me know.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Ps3 slim 129 gb will mot eject mw2 it makes the beebing noise and the another weird noise that sounds like it is stuck and the doesnt work the games does eject from the main menu but it is still in the ps3
1. First shut down the system by flipping the power switch in the back off.
2. Hold down the eject disc button.
3. While still holding down the eject button, flip the power switch to turn back on your PS3.
4. When the green light comes on, wait a few seconds then tap the eject button a couple times. The fan will run on full power and the disc will eject.
Nov 23, 2010 | Sony Playstation 3 (PS3) Console
My game is stuck in my ps3 and is making a clicking noise
have you tried to tell it to eject from the game disc options using triangle button ? just a thought but it sounds quite critical if its clicking like your ejection drive is having issues hope this helps
Nov 17, 2010 | Sony Playstation 3 (PS3) Console
Wheni put a disc in the ps3 it does not load up so i cant play on games my software version is 3.21
hi,
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
The drive will not eject games, and will not read games once removed. The drive just makes a whirling sound and I have to hold the ps3 @ an angle just to eject games. And now the drive won't accept...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the PlayStation not ejecting discs is a bad drive.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This drive should fix any issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PlayStation including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PlayStation going again!
May 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 makes a clicking noise when i load a disc
hmmmmm mayby wask the disc be you play and remember to dry CARFULLY
also PS3's and everything els like to be laid down not stading up that helps them alot
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
Ps3 is not reading my discs
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise it goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Blu Ray drive not working
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise i goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 16, 2009 | Sony PlayStation 3 40GB System
Playstation 3
As for the disc, you have a slipped gear in the BR drive. It sees the disc is there and it's trying to eject it, but one of the side arms inside isn't aligned with the gears. I suggest calling Sony first, if they will not fix it then find and contact a pro. I hope this helps. Good luck.
Jul 23, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
259 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
