When I turn on the tv the blue light comes on and blinks once then there is no picture. My tv is model FLM-373B.
  • 1 more comment
  • ted-542 Sep 03, 2008
    This did not tesolve my problem. I do not have a projection tv. Mine is a LCD.
    What is a crt lamp?
    I have looked for a master reset button but I cant find it.
    Master:
  • 521 Answers
If the reset method does not help you.then its the problem of faulty ic in the capacitor which is not supporting completely to the board to keep the tv ON.so you have to get replaced that --ic-- on the power supply board.it will not cost u much as the tv starts for a moment then shuts .it will be not more then the service charge.please do not try without perfect knowledge.as it may damage the board.your tv is perfectly all right.nothing to worry just get changed the --ic-- and it will work.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
    President:
  • 1,263 Answers
Have you unplugged the unit and let set for a while? have you tried to rest it with the master reset?..if that has not worked you have a power supply issue to your main board. do you have audio? if you do you have a convergance issue. i suggest checking these first. if you can't get either the unit to reset then a service tech should be contacted. start with the simple fixes likie does the unit turn on with the remote or the button on the unit or not at all. if these suggestions don't work your best bet is to either have it repaired or take it back if it is under warrenty.
  • 19,396 Answers
It can be a problem with the CRT lamp. Probably you need to replace the lamp.
  • Ginko
    Ginko Sep 04, 2008
    First: your FLM-373B Polaroid TV is not a rear projection, therefore there is no lamp building the image, the only lamp in your tv is the LCD panel rear lamp. Therefore there is no lamp involved in this fault.
    The "faulty ic in the capacitor" described from the Techexpert here, does not make any sense, there is no "ic in the capacitor", not in any electronic device on earth.
    The fault is a problem on one of the pcb boards inside the TV, you have 12 boards or so inside your TV with several thousend components
    Here ypu get the part list with all parts for your TV set
    Polaroid Replacement TV Parts, Modules & AccessoriesThe technician willo start by testing the power adapter, then testing the internal components.
    If your TV is less than one year old is still covered with factory guaranty.
    If you need service call the number listed at the end of the user manual.
    Genius:
  • 1,142 Answers
Did you try to hard reset the unit by unplugging it for 2 hrs and then connect it back ?
FLM-373B Polariod tv codes
try this:
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • Jun 01, 2010 | Directv RC23 Remote Control
    Tip
    Polaroid FLM-373B Manual Download
    Download Polaroid FLM-373B LCD HDTV Manual
    Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
    Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
    Models: FLM-3734B / FLX-374
    Have you misplaced your Polaroid FLM-373B LCD HDTV Owners Manual?
    Would you like a digital, searchable, pdf version of the Polaroid FLM-373B LCD HDTV Users Guide?
    Follow this link
    (& click FREE) to download a pdf version of the operations manual.
    I hope that helps.
    _____________________________________________
    Polaroid FLM-373B Service Manual Download
    on May 01, 2010 | Televison & Video
    Tip
    Download Polaroid FLM-373B LCD HDTV Service Manual
    Have you misplaced your Polaroid FLM-373B LCD HDTV Service Manual?
    Would you like a digital, searchable, pdf version of the Polaroid FLM-373BLCD HDTV Service Manual?
    Follow this link (& click FREE) to download a pdf version of the operations manual.
    I hope that helps.
    Polaroid FLM373b No power.
    When the filter capacitors went out , the power supply will feed AC instead of DC into the circuit board and may have damaged other circuits. Do you get the 5vdc standby voltage? it should be on one of the power supply out put connector the minute the you plug in the TV, you must have this before go further.
    Dec 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
    Polaroid lcdtv flm-373b
    its the problem in the power supply board of your tv. any of the capacitors or ic are loose on the board.check it out and make it proper,
    Oct 26, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
    Tip
    I hope that helps.
    on May 01, 2010 | Polaroid FLM-323B Television
    Tip
    Follow this link
    I hope that helps.
    Flm-373b lcd tv will not turn on. red light turns to blue but wont come on.
    There is a guy who fixes that tv at www.mikecampagna.com/Polaroid
    Jun 10, 2008 | Televison & Video
    Polaroid Flat Panel TV FLM 373B
    I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
    Apr 13, 2008 | Televison & Video
    Televison & Video Logo
    Top Televison & Video Experts
