Question about Dryers
Dryer On Switch
When you push the button to cut on our dryer the dryer will come on but when you let go of the switch, it goes off. Any suggestions?
  • 1,543 Answers
If you're really lucky it may be a broken or burnt off wire at the motor, but more likely you have a bad motor. When you push the start button you are energizing the start winding on the motor, but if there is no circuit through the run winding the motor will not continue to run when you release the button. Could be a bad run winding or the centrifugal switch is not resetting when the motor stops. Either way you are most likely looking at a new motor (expensive and usually a pain to install) or replacing the dryer. Sorry for the bad news. (remember good advice = fixya rating)
Posted on Sep 03, 2008
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
Dryer requires start button to be depress constantly for dryer to operate
If I am not mistaken, once the timer is set and the button pushed, the motor should run and there is probably a contact in the cintrifugal switch of the motor to seal in the run circuit. On a working dryer, if you push the start button for a split second, and let go the dryer will stop. This is because the motor has not reached proper rpm and the switch is not made yet. If the switch hangs up or the switch goes bad the same symptom will occur.
Aug 30, 2011 | Roper Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is doing nothing when I set the time and push the start button. I have omed out all the fueses and have made sure the door is shut. I have used my multi meter and I am getting the corect voltage....
Check your door switch. It should be a normally open switch. If it's good, you will need to check the thermal fuse and or thermal cut off. This is where you will find the problem. When you find the one bad, you will need to replace the cycling thermostat. It's a normally closed switch that closes on the rise. Once the temp gets to the degree on the cycling thermostat it opens, cutting power to element. When it goes out, it will not open. Then the dryer cycles off of the thermal cut off. This results in the dryer getting real hot and then the thermal cut off will be put out or the thermal fuse one. Your on the right track, keep looking and I feel sure you will find it. By the way, these parts I listed are located on the vent housing close to the blower housing. Good luck.
Oct 16, 2009 | Kenmore 700 6972 Dryer
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not cut on, the switch to push the button for turning on the dryer has no power to show the tester light on.
First verify 220 volts of power at the terminal block where the cord attaches to the dryer. Also, look for a burned or loose wire at this location.
The power to the start switch comes from the door switch.
Check the door switch for continuity.
If no continuity, replace the door switch.
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Whirpool estate dryer teds680eq2 does NOTHING when start button is pushed.
NO POWER CAN BE A MULTITUDE OF PROBLEMS.
1 DOOR SWITCH 2. THERMAL FUSE. 3 MOTOR 4. TIMER
5. HOUSEHOLD VOLTAGE. 6. PUSH TO START SWITCH.
CHECK ITEMS IN THE ORDER LISTED.
THE DOOR SWITCH HAS AN ARM THAT EXTENDS DOWN INTO THE SPACE WHERE THE DOOR CLOSES. IT IS LOCATED IN THE UPPER RIGHT CORNER. PRESS IT WITH YOUR FINGER TO SEE IF IT CLICKS. THEN CLOSE THE DOOR AND SEE IF IT CLICKS WHEN THE DOOR SHUTS.
IF NO CLICK, REPLACE THE SWITCH.
THE THERMAL FUSE IS LOCATED BEHIND THE LOWER BACK PANEL OF THE DRYER DOWN BE THE EXHAUST. IT IS A SMALL WHITE ITEM WITH TWO WIRES ATTACHED.
JUMPER ACROSS THE TWO WIRES. PUSH THE START BUTTON. IF THE DRYER COMES ON, REPLACE THE THERMAL FUSE AND CHECK FOR PROPER OPERATING TEMPS.APPROX 160-175DEGREES FAHRENHEIT.
IF IT GOES BEYOND 220 DEGREES, REPLACE THE CYCLING THERMOSTAT LOCATED BESIDE THE THERMAL FUSE.
THE OTHER ITEMS SUGGESTED ARE MORE IN DEPTH AND REQUIRE A KNOWLEDGE OF READING SCHEMATICS.
Apr 16, 2008 | Dryers
Dryer wont stay running
Either the motor relay, or if this is an evenheat dryer, the evenheat control board could be bad.
Jan 06, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
