Question about Weather King 10AJA2501AH Air Conditioner
Capacity The square footing area of my house is 1500 sq feet, at present a weatherking efficiency furnace is been installed can you help me to calculatethe capacity of A/C unit that this house needs, it is a bungalow, R24 insulation, I think that a unit of the same kind (Weatherking) would be most apropiate for this application. Please suggest. Patricio, in Canada
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
You have to take in accounts of how many windows, facing the sun, which way the house face during the day, attic insulations ,wall insulations, floor insulations, types of windows, its best to just have a professional do a load calucalation.
Posted on Sep 04, 2008
How much area is a square foot?
A square foot is by definition 12"x12" or 144 square inches. Measure your area in inches, multiply the length by the width and divide the total by 144 to figure the square feet.
Feb 24, 2015 | Building Materials
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little boxes.so in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
Convert 2,000 cubic ft to sq ft
Cubic foot is a unit of volume. Square foot is a unit of area. There is no conversion.
Let's say you have 2000 cubic feet of mulch. That can cover a 2000 square foot yard one foot deep. It can also cover a one square foot flowerbed 2000 feet deep.
May 19, 2014 | Miscellaneous
How many feet is 350 linear feet?
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144:
2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
Apr 08, 2014 | Cars & Trucks
What size oil furnace is needed for 1200 square feet?
75000 to 85000 btu Or British thermal pound.
Two units of measure are important in sizing an oil furnace. The first is the British Thermal Unit or BTU, which represents the energy needed to raise the temperature of one pound of water by one degree Fahrenheit at normal atmospheric pressure. The input capacity of an oil furnace is often stated using this unit of measure. The second number is the fuel efficiency rating, which is expressed as a percentage. This represents the amount of energy that gets converted to heat, with higher numbers being better. To determine the energy output in BTUs per hour, multiply the input BTU by the efficiency rating. For example, a furnace with 100,000 BTU of input and an efficiency rating of 89 produces 89,000 BTUs of output. One with an efficiency rating of 80 and the same input amount, produces only 80,000 BTUs of output.
Read more: http://www.ehow.com/info_12197488_size-oil-furnace-required-1200-square-foot-house.html#ixzz2jfsuqLFx
Oct 25, 2013 | Heating & Cooling
What's the conversion formula for sq. ft. to sq. meters?
The square foot is the smaller unit of area, so you will have to divide a measurement in square feet by the number of square feet per square meter. Since there are 10.76 square feet per square meter, divide by that value.
Obviously, to convert from square meters to square feet, you would multiply by that value.
1 square meter is 10.76391 square feet.
Feb 13, 2011 | Garden
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
Hi, we have a problem with our Weatherking heating unit/ air conditioner. We had it installed 07/20/06. It really never has worked properly. For the last 2 summers in run's constantly. Which of course...
Lets look at the whole problem. Did you have a new unit inside. Is the charge correct for unit. 1 lb of refrigerant makes difference. Four tons should be big enough if you have proper insulation. I have three tons in a 2100 square foot house. Its plenty big enough. You may have to small a return air. To small a return can cut a four ton unit to 2.5 ton unit very easily. 1.5 square foot pf free grille area per ton. Rusty
Jun 08, 2009 | Weather King 12AJA4801AH Air Conditioner
Conversion of 1900 sq. foot to square meters
An area of 1,900 square feet is equal to 176.52 square meters since there are 10.7639104 square feet in 1 square meter based on 3.2808 feet in 1 meter.
Alternately, there are online converters for most measurements.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 23, 2008 | Office Equipment & Supplies
Weather King 10AJA2501AH Air Conditioner Logo
135 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
