Service menu codes for RCA R52WH56 - Televison & Video
I need a service menu code for a rca sld58g45rq tv.
this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
* Turn the TV off.* Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
* The TV will turn on with the Service Menu displayed.
* Press the {POWER} button to exit. thank you..
Nov 04, 2017 | RCA Televison & Video
RCA 42 in Replaced the 42RE010C878LNA0-A1 Board now a good picture but upside down how do I fix it
from remote press menu and highlight contrast enter code 1950 and see the service menu comes up. if not try 9735 same way.and change product id in service menu. try different .ids. each time you change id unplug tv and plug in .see if picture change.or do same process each time until show good.
Jan 19, 2015 | RCA 42la45rq 42-inch 720p lcd tv
RCA 52" model D52120 i have the following codes
Sorry we are not able to help you with your problem
Dec 05, 2010 | RCA D52120 52" Rear Projection Television
How do I get into the service menu of my 32LG30-UD. Not the settings menu that I get by pushing menu, but the actual service menu where i can adjust the balances, and other adjustments?>
You can get an rca rc807-b universal remote control. Remote programming code is 009 for that TV. After programming the remote to the tv, You need to press L2 on the universal remote to get in to service menu options. Password is 0000. Risk is yours!!!
Aug 07, 2010 | LG 32LG30 32 in. LCD HDTV
RCA Remote (RCR312W) Code for Sharp Television (19R-M100)
I found that this website should have all the codes and instructions for most remotes
if this helps please give a fixya rating
Jul 14, 2009 | RCA 3-Device Universal Remote with...
I have dish network and i am trying to program my Symphonic DVD player to my remote and i can't find the codes for my dvd do you know of any?
The web page link below will take you to the RCA Customer Service website page for your model RCA 3-Device universal remote control model number RCR311S. On this page is all the service information for your product. The DVD code for Symphonic DVD players is 3436. You will find this code and all the other codes for your remote control on this page under code lists for RCR311S. I hope this information helps you solve your problem with the remote code number for your Symphonic DVD player. Thank you for using FixYa and have a nice day! /
Jun 21, 2009 | RCA 3-Device Universal Remote with...
Rca d52w23 convergence problem error code 84
Go to menu then setup does it have convergence on menu if not then you have a open fuse FL231 it will be the middle fuse there will be 3 of them on right side of FBT flyback transfomer.let me know!
Feb 16, 2009 | RCA Televison & Video
RCA 32" TV
Many RCA's use the following to gain access:
Hold the 'Menu' button while turning the set on.
The code may also be inside the back cover.
Feb 20, 2008 | RCA F32650 32" TV
Rca p2937sg convergence
He could need the orginal remote or atleast one that is close to get in the service menu for this set. If you did not have the remote or he didnt know how to get into the service menu this could be true.
Jan 14, 2008 | RCA P52937 52" Rear Projection Television
RCA P52921 Color/Alignment Grid
What your looking for is called the service menu. This is not an adjustment you should attempt unless you first read the service manual as the wrong button pressed while in this menu will cause permanent damage and an expensive repair. My best suggestion is for you to call in an authorized RCA repair person to do this for you, or purchase a service manual before you attempt this alignment procedure. Good Luck
Sep 28, 2007 | Televison & Video
Televison & Video Logo
239 people viewed this question
Top Televison & Video Experts
