Question about Goodman CKL60AR60 Air Conditioner
Compressor I have been told I need a new compressor because the volts were reading high at 29? I have a five ton Goodmans unit and it is six years old and he recommends getting a whole new unit for 3200.00
  • bossyq Sep 03, 2008
    thanks hillbuck29. I will do that.
    Problem Solver:
  • 6 Answers
A couple of issues here.......... 1) 29 sounds more like amps and not Volts. 2) if the amps are high at 29 amps that generally indicates that the compressor may be overloaded. There are several reasons for overloading of the compressor. It could be overcharged, this is common from fly by night AC repairmen they take advantage of consumers because there is not really a good way for the customer to know what the refrigerant levels/temps/pressures should be. Another potential problem is a dirty condensor not allowing the refirgerant to cool and condense in the outside unit. Lastly the inside unit could be dirty causing freezing conditions in the evaporator (inside unit) thus causing the compressor to work harder inturn causing more amps...... Now with all that said, the compressor has no impact on over VOLTAGE, this is something that is controled by the local power company... Hope this helps....
Posted on Oct 03, 2008
  • 182 Answers
Get a second opinion from a different company
Posted on Sep 03, 2008
I have a toshiba flat screen TV about 2 years old. The annoying problem is that in the middle of NCIS the characters are talking but I can't read lips. Missing the audio happens five or six time
I have noticed a similar problem and after reading a circular that arrived through the post, I am beginning to suspect it is being caused by the new 4G mobile phone networks.
The circular offered a free filter to prevent such interference.
Nov 13, 2017 | Televison & Video
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
5 ton split LG UNIT brand new about 1 year old.
Look up the term BLACK DEATH.
90-100 psi is very high on the low side.
Without spending too much time,I would pull a vacuum to -28 inch of mercury and let it sit over night.
Monitor the manifold garage for leak. (rise of inch of mercury)
My bet is the low quality LG compressor's worn out metal part is in the condenser.
Blockage will increase the low side PSI.
You can buy HVAC blow out can/chemical to clean line before you vac and fill the refrigerant.
Please let me know what's you founding is on reply.
Jul 11, 2010 | Whirlwind FH-778 Air Conditioner
No cooling at all
I have been out of the air conditioner service sector for a while. I wanted you to know up front that I may be out of date. When running service I replaced many compressors for a fraction of the cost of a new unit. Many of these customers had been told the same thing. Service companies make allot more on a new unit than they do repairing an old one. Many don't have anyone capable of replacing a compressor. Get more than one opinion and if you replace the whole unit get more than one bid. Make sure all of the bids are for the same tonnage, or btu unit. Some lower bids are for a smaller unit that won't keep up after it has a little wear or the coils get a little dirty. If your unit is more than ten years old you should consider a new one. If not, if you can find a honest company it should be worth replacing the compressor. Replacement compressors, if installed by a certified tech, have at least a five year warranty.
Jul 06, 2010 | Weather King 10AJA6001AH Air Conditioner
Compressor size
Square footage is how you determine what size of an AC you need, say two bedroom house with 1500 square feet would require a 3 ton unit but I would go to a 4 or 5 ton depending on brand and what you may do in the future, Like adding a bedroom or bathroom and how many people will be living in the house, a heat pump normally last longer the bigger it is and is more efficient than a smaller size. Just think like this, a 3 ton will run 30 minutes to an hour longer to cool the same space as a 5 ton so if the five ton does it 30 minutes faster it will not run as long. And when it has to pull down the temperature again it will do it much faster. So less run time means faster heat or cooling and less energy is used. I have found that the bigger units are made better and last longer as a general rule. And to understand the 3-ton and 5 ton let me say that it means how long it takes 3 tons of ice to bring the temperature down 10 degrees, the old BTU’s British thermal units. However the bigger the unit the more well built it is normally and the less maintenance required. 5 tons of ice would get it cooler faster. But one thing to keep in mind a heat pump is only good for 20 degrees temperature range, for instance if the high range is 80 then the low side would be 60 in order for it to be efficient so if you have it set in the house at 72 degrees on the high side and low side would be 52 degrees. But the larger the unit the less time it would take it to recover from the heat differential.
Jul 22, 2009 | Ruud UAKA042 Air Conditioner
3 Ton Ruud compressor
Is the unit over five years old? If so it is a fair price for conpressor, parts, labor and refrigerant. Have him give you a firm price. If it is an older unit, say over 10 years, and you have the money replace the complete system
Jun 15, 2009 | Ruud Handle Air Conditioner
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Weather King 10AJA6001AH Air Conditioner with bad compressor
If it is five years old it is either right in or out of warranty a service tech can determine this through the serial number. If not the unit is only a little bit more to replace than the compressor. A replacement compressor is only warrantied for one year verses a unit replacement with five years on the compressor and one year parts and labor.
Oct 04, 2008 | Air Tools & Compressors
Compressor went out on 4 ton unit. want to upgrade to 5 ton A/C. Have been told need bigger blower unit. Can I exchange to blower unit that will handle 5 ton A/C?
Hi mans1930. You need to replace the whole inside blower unit, the coil as well as the blower. If not, there would be a very good chance of damaging your outdoor unit, namely by ruining your new compressor.
Greg.
Aug 18, 2008 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
113 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
