I have a Compaq M300 laptop which is unable to boot up. I turn it on, The logo comes up saying preparing to boot then immediately the screen goes black and there is a blinking cursor in the upper right hand corner. I cannot type, write any commands..nothing and when I click on any key, I only get an error noise. It there any way this can be fixed.
    Champion:
  • 200 Answers
Well as i know its either the hard driver is dead
or the windows is corrupted.
so in case one you will need to replace the hard drive.
but in case two you will need to reinstall windows
so lets do the reinstallation first and see if that is gonna work
you know first you will need to go to the boot menu and make the CD drive the first boot device and insert your windows CD and then start the installation process.
by the way if u dont want to remove everything from your computer (due to installing windows) then when u have the installation options (enter, R -key or F3- key) select enter.
in the next list of options (select the repair option now).
that should fix your issue without removing your data
i hope that will help
cheers
Posted on Sep 03, 2008
    President:
  • 2,961 Answers
Try pressing F8 while it's booting up, then choose last known good configuration and press enter,and then when the system will load or if not do same again but this time press safe mode and then when the minimum of drivers load click on your account and try system restore to a previos date.
Hi i have a compaq presario laptop and after it stars up the screen just goes blank
do you still see the compaq logo and does it show you the windows boot up screen before it goes blank?
OR
do you see anything on the screen at all after pressing the power button?
Check if the laptop is receiving power. If it has power and you can't see anything on the screen it could mean that the LCD assembly or the Video card of your laptop is bad.
If it goes to the compaq screen and then to windows logo before going out, try booting into safe mode and once there uninstall the video driver from the device manager because that means the resolution was set to something higher than the display could handle.
If it restarts after showing the compaq screen try reseating the memory, hard drive and wireless card of your computer put them one by one and try turning the compter on after each part you put back to check which component is point of failure.
Otherwise you have a bad motherboard and it may have to be replaced.
Hope this helps!
Jul 27, 2011 | Compaq Presario 700 470024-192 Notebook
My laptop will turn on the compac screen comes on then the screen goes black
Alright, does your laptop after the compaq logo come on goes black and is there a blinking scroll or does it say anything afterward? If so, it could be a harddrive failure, you can check this to make sure if it is the harddrive if you can go into the bios menu and see if the harddrive is presented. If it is not, then you probraly have a bad hard drive and it not loading after the "post" test.
Jan 18, 2011 | Compaq Computers & Internet
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Screen goes off
Try booting into safe mode.. press F8 before the windows screen, and select Safe Mode as the boot option. If that is a temporary fix, then reinstall the driver, and make sure your Hertz settings are correct!
Aug 07, 2008 | Compaq Evo N610C Notebook
BLANK SCREEN
i think your system has crashed so you need to do recovery or do a fresh installation of your operating system. Your system is unable to boot due to corruption in system files.
Jun 18, 2008 | Toshiba Satellite A135-S4527 Notebook
Operating system not found
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Presario 1693 issue
Go to (CMOS) Setup at boot and "detect" your new hard drive.  Then boot from your operating system CD and prepare (partition, format) your new hard drive and let your OS install.
Oct 15, 2007 | Compaq Presario 1693 (153296-007) PC...
Can't boot up laptop
If your Usb port works, then the mobo is working, so possible graphics problem. Try booting up in safe mode(normally pressing F8) on boot up then highlight 'start windows in safe mode', to see if Windows will load with only minimal drivers, if so restart again, pressing F8 again, but this time highlight 'start windows with last known good configuration' Doing any of these 2 things can be done in any order, either last known good config first or safe mode.
Oct 21, 2006 | Compaq Presario 2140US Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
