Question about Zebra Z4Mplus Label Printer
Change label size
Hi, I am new to Zebra Thermal printers. I have a Z4MPlus and I need to change the label size from 4"w x 6"l to 4"w x 2.5"l.
How do I do this?
Thanks!
Steve
  • 1 more comment
  • dmoney78 Sep 04, 2008
    I am having issues with my Zebra 220XiIII Plus (203 dpi) printer. It currently prints labels out fine when I have 4" x 8" labels in the printer but when I change the labels out to 4"x4" labels the labels print out all blank. This even happens when I goto the printer and print a test page directly from the printer. Help!
  • BigPoppi Sep 05, 2008
    I have a ZebraS4M printer. I can't print a 4 X 6 Label. For some reason it thinks it is a 2 X 3 Label. I changed the size in Zebra Designer. Can't print a test page though, it flashes Data on the Printer but no test page prints. If I print a form layout and have it rotated 270 counter clockwise it will print only those fiedls that fit in the 2 inch range. It prints blanks when I rotate it 90
  • BigPoppi May 11, 2010
    I did all that and it still does not work. I print from an AS400 iseries 520 using a Software called MarkMagic. No matter what I do it still does not go past 2 inches as the length. The printer is 300dpi.
  • Zebra Master
  • 2,794 Answers
Turn the power off. Remove old stock. Load new stock. Turn power on. Restart your program. Form size is software controlled from your form settings downloaded into the printer before your print. Make sure you restart your software to reload them.
Posted on Sep 03, 2008
Zebra Printer prints incomplete Label.
Run a config label and see if you have the same issue. Power it up while holding cancel key is the easiest way to do that.
Oct 28, 2015 | Zebra Z4Mplus Label Printer
How to reset zebra z4mplus dt printer setting
Factory Reset
Press Setup/Exit - 2 Times
Press '+' - 3 Times
Press 'Select' - 1 time
Jul 14, 2010 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus won't calibrate 2" Circle Labels
try to set the printer to the factory default setting
Aug 13, 2009 | Zebra Z4M Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Label size
Set the label size in the label program and then calibrate the printer.
Jul 11, 2008 | Zebra Z4Mplus Label Printer
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Zebra z4mplus printer resets to thermal transfer
Please go to the inhouse program & click printer properties and
change the printer setup to direct thermal and that's it.
Joe
Dec 12, 2007 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
1,134 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
