Question about HP OfficeJet 7310 All-In-One InkJet Printer
Fax issue Hello, When faxing either from the scanner bed or through the document feeder on top i keep getting a gear stripping/jumping teeth sound. The screen prompts me to shut off the power and re power, but to no avail. The report tells me that there was a power failure. Thanks Jeff
  • br459x17 Sep 04, 2008
    Hello Katz2002ph,
    Yes the printer is pluged directly into the wall. Should it be done diferently? I made a copy with the lid open and it seemed fine. I never have the problem when copying. ONLY when faxing. And like I said either thru the document feeder or from the scanner bed it does the same thing.
    Thanks Jeff
    Problem Solver:
  • 11 Answers
Did you plug the printer directly to the wall outlet??
Coz if you do, there is a hardware problem with it. Probably on the scanning mechanism. try to copy with the lid open and try to check if the mechanism has some problems running from right to left or vice versa. If it has some problems, there is nothing much we can do about it.
Posted on Sep 04, 2008
  • Kristian Kate Cajoles Sep 05, 2008
    Try to do a full reset of the printer by:
    > unplug the printer without turning the printer off
    > then press and hold the power key for 5 seconds
    > then press and hold the pound key "# " and number "9" while plugging in the power cord.
    > release the both buttons when the display prompts you " NVRAM Reset"
    > run through the alignment process then try to fax either on the feeder or on the scanner glass.
    > tell me the results
I am trying to send a fax on my parents fax machine but do not know which way to insert the paper. It is a brother MFC-7860DW
  • if you are going to fax from the glass or scanner bed you should put your document face down on the glass
  • if you are going to fax from the feeder (on the top of the machine) then you should load your document face up in the feeder
How to send a fax?
  • when you want to send a fax ,press the FAX key to illuminate it in blue
  • put the document either in the feeder or on the glass
  • enter the fax number using the dial pad
  • press START
Jul 29, 2011 | Brother Office Equipment & Supplies
I am trying to fax on the 6170 do the sheets face up or down?
If you are sending fax using the scanner bed, your original document should be placed face down. However, if you are sending faxes using the automatic document feeder, original document should face up.
Jun 15, 2011 | Lexmark X6170 All-In-One InkJet Printer
What is the procedure to send a fax
To send a fax using the printer operator panel, load the original document on the scanner bed or in the document feeder > press the Fax mode > enter the fax number > press Start Color/Black. For more information on how to use the Fax function on your Lexmark X6500 Series printer, refer to the Lexmark X6500 Series User's Guide.
May 27, 2011 | Lexmark X6570 InkJet Printer
How do I fax a sheet of paper?
First step is to connect the phone line to Line 1 Ext at the back of the printer port.
Place the document face down on the Scanner Bed Or place the document face up on the Top feeder if you want to use it.
Use the right arrow key and choose Fax Black and press OK
Dial the # you want to send Fax to and Press OK.
The fax should be sent.
Regards,
Ron
Dec 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
When I am faxing to someone my outgoing fax comes through with a line running down the middle. How can I fix this?
Hi. Try to open the cover for the scanner bed. You'll see 1 big glass and 1 small strip of glass on the left side. The big glass is used for scanning using the scanner bed. The small strip is used when paper is going through the feeder. Wipe the glasses thoroughly with a soft cloth. Hope it's just a dirt that's causing the problem. Good luck!
Mar 11, 2010 | Lexmark X5495 All-in-One &USB...
How do i send a fax ? mfc-240c and where to insert paper.
To send a fax, you need to have a working phone line plugged into the jack on the left hand side of the printer. If you are faxing one page, place it on the scanner bed (the glass) and close the lid, then press the Fax function button, type in the phone number to fax to, and hit Start.
If you are faxing multiple pages, it is the same process, but instead of placing the paper on the scanner, you would place it in the document feeder on top of the printer, and each page would scan through individually. (Make sure none of the pages are stapled or paperclipped together.)
Dec 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
Lines on fax going out, fine receiving fax
check the scanner glass under the cover where the documents are fedd through if you lift the lid on this you should see a thin slip of glass if this has ink or usually tipex on it the lines will be on every fax that goes out.. there might be a small roller over this that has a clip each end you can take this out for acces to hte glass
Jul 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Hp officejet 7410 fax failure
Had the same problem as everyone else here - would copy fine but faxing or scanning resulted in the "whizzzzzz" sound (with or without the sheet feeder) and a mandatory reboot.
I followed the suggestion of moving the scanner head to a different part of the drive belt and it works fine now (at least until that part of the belt wears down!). Here was the procedure - it took about 10 minutes.
  1. Remove all T8 screws from the top of the scanner bed - there are two hidden on the left side under the removable flap and two more hidden behind the front control panel cover, which just snaps off.
  2. There is a bundle of wires that prevents the entire top from lifting completely off, so lift it high enough to clear the plastic parts, then rotate it 180 degrees around and set it on something to support it.
  3. Lift the scanner head until it comes off the guide rod and disengages from the drive belt.
  4. Move the scanner head to the other end of the bed and reingage it onto the belt and guide rod - this is a little tricky to get the belt to pop back into the scanner head, but I got it to go by holding the belt firmly on either side of the head and squeezing both together.
  5. Replace top and all screws, pop control panel cover back into place.
  6. Rejoice in saving yourself lots of $$ and preventing more junk from entering the landfill!
Feb 29, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Jan 22, 2008 | HP OfficeJet 6310 All-in-One Printer...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
79 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
