Question about Toshiba Satellite P205-S6287 Notebook PC
Setting up wireless internet on my laptop
My new laptop includes a Wi-Fi Link 4965AGN. What is the process to get it up and running?
  • savagebdl Sep 03, 2008
    Thanks. I was hoping that it was that easy.
    President:
  • 1,263 Answers
Go into your network connections a click on the available networks. it should bring up the screen that shows all the networks in your particular are you will have either secure, in wich case you will need a pass code in order to gain access or an unsecure in which case you just click on it and you will be able to surf the web....... please rate this good luck and thanks
Posted on Sep 03, 2008
MY PROBLEM HOW TO CONNECT WIFI
setting up a Wi-Fi connection is the same process as setting up a wireless Internet network.To get help,see:Setting Up a Netgear Wi-Fi Router
Aug 26, 2012 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
IBM ThinkPad T40 no LAN or internet connection
Fot that first you need wi fi router with intenret connection .
Then check in your laptop that your wi fi network adapter driver are installed.
Also check its wi fi switch is turn on it is on laptop.
Check your wireless in router is enabled.
also check your wi fi network adapter is enabled in your LAPTOP.
Let me know if you want to configure your router and if you need more assistanse .
thanks.
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
My computer doesn't recognize my wireless card. Driver install didn't help.
D-Link AirPlus G DWL-G630 Wireless Cardbus Adapter 6.0.1.1 ... Intel Next Gen Wireless Wi Fi Link 4965AGN card suitable f ... I uninstalled mine and my computer did not find it and thus did not update it any suggestions? ... I m in Brazil and HP doesn t give any assistance for this model Do you know ...
www.soft32.com/download_179407.html - United States
Jul 02, 2010 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
My ipod touch is not connecting to the internet even though my wireless router is up and running
DEAR SIR, YOUR IPOD TOUCH IS NOT CONNECTING, IT MAY B THE REASON THAT UR IPOD'S WI-FI IS NOT WORKING OR SETTINGS OF WI-FI ARE NOT CORRECTLY DONE. KINDLY DO SETTINGS PROPERLY, IF NOT, THEN CHECK THAT YOUR ROUTER IS PROCESSING YOUR WI-FI OR NOT. THANKS. PLEASE RATE ME...
Feb 10, 2010 | Computers & Internet
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Acer wireless dirver for XP
This model has one of two makes of Wifi card/chip installed its either;
1 Intel® Wireless WiFi Link 4965AGN (dual-band quadmode
802.11a/b/g/Draft-N) Wi-Fi CERTIFIED® network
connection, supporting Acer SignalUp™ with InviLink™
Nplify™ wireless technology
or
2 Intel® PRO/Wireless 3945ABG (dual-band tri-mode
802.11a/b/g) Wi-Fi CERTIFIED® network connection,
supporting Acer SignalUp™ wireless technology
If you have the incorrect driver it wont install
Hope this helps
here are the links for you to download the correct ones
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Atheros_%207.2.0.215_VistaX86.zip?acerid=633639023394558300&Step1=Notebook&Step2=Aspire&Step3=Aspire%202920&OS=V10&LC=en&SC=PA_7
and
http://global-download.acer.com/GDFiles%5CDriver/Wireless%20LAN/Wireless%20LAN_Broadcom_%204.170.25.19_VistaX86.zip?acerid=633639023397522319&Step1=Notebook&Step2=Aspire&Step3=Aspire%202920&OS=V10&LC=en&SC=PA_7
Aug 10, 2009 | Computers & Internet
Wi-fi card on Win98SE laptop not allowing internet to connect.
I really believe this is some kind of driver error. You must first remove the existing driver and then install the following driver.
http://download.cnet.com/D-Link-AirPlus-Xtreme-G-DWL-G650-Adapter/3000-2112_4-67890.html
If that doesn't work we're gonna have to try messing with the wireless router settings.
May 26, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Toshiba Satellite P205-S6287 Notebook PC Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
