Question about Gateway Computers & Internet
Motherboard I am trying to find which Gateway motherboard I have to see if it has a BIOS reset switch. I was working on my son's computer. I cleaned off all his stuff, ITunes, steam, ect... and I took out the cards we put in like the video upgrade card, linksys, wintv.... I then made a save point for the system restore. All was well. I then put the linksys card back in trying to hook up to the router but I did it while the computer was on, which may or may not have caused the computer to go down. I turned off the computer then on several times to try and reboot. Nothing. I did the off/on so much that the blue on light went out. It will not boot up. Someone said to see if it has a reset on the motherboard. The board has KTBC5IGLF in big letters on it. Any suggestions?
    President:
  • 2,961 Answers
Bad idea changing pci cards when the board is live, if youre lucky and it works, look for a 3 pin terminal with a jumper on it labeled JBAT1 CLRCMOS or CLRCLK or similair, put jumper across the pin unused and then back again normally pins 2-3 then back to 1-2
Posted on Sep 03, 2008
You can bet that the motherboard is dead now. You should never plug or unplug any interior component while the PC is running and/ or plugged into any power source for that matter.
First shut down the computer, unplug it from the wall, wait a minute for any electrical serge to dissipate. Then it's okay to fiddle with the interior components.
Note: Most interior components are sensitive to static electricity, so use caution and avoid handling and/ or touching sensitive areas of components, i.e. PC Boards and conductive areas. Also, as precaution you should invest in a anti-static wrist band.
Posted on Sep 13, 2009
Gateway manuals
It depends upon whether we are talking about the windows password or the password on the motherboard (bios). To reset the bios password (on a desktop P.C.) you will need to firstly unplug the power at the wall socket,. open up the computer case and remove the battery that powers the chip holding the password. There will be instructions on how to do this in the motherboard manual or on the motherboard manufacturers website. There will also be a small piece of plastic called a jumper which bridges two pins on the motherboard. It will be located near to the battery (a large button cell type) once the battery has been removed (with the power unplugged) briefly move the jumper from the working setting (as it is now) to the reset position. then return the jumper to the working position, replug the power and switch on the P.C. You should receive messages telling you that the bios settings are incorrect and instructing you to press a keyboard key in order to enter the bios setup program. upon pressing the correct key you will be presented with a menu system to reset the date, time, and various options which will include (security) where the new password can be selected. You may choose not to install a password, or set two passwords, one for general use and one to restrict access to the bios setup screens. You may choose to load default values or failsafe values. once saved (press the F10 key) the computer should restart with the values inputted. If you have set passwords you will need to input the new password.
Feb 01, 2014 | Computers & Internet
Remove bios password
BIOS, which stands for Basic Input Output System, is the most low-level operating system on your computer.
BIOS is responsible for automatically performing a number of tasks, such as setting the clock speed of your computer's processor and determining the timings of your computer's memory.
Resetting a BIOS password on your Gateway computer can be accomplished in multiple ways, so choose the one that best fits your situation.
· 1
Navigate to xs4all.nl and attempt to use the master passwords contained therein (see below). http://www.xs4all.nl/~matrix/mpwlist.html
These are BIOS passwords built into the system that can be used by technicians and other service personnel when working on an otherwise locked computer.
·2
Contact Gateway and speak to a customer service representative about obtaining a master password for your particular model if none of the passwords in Step 1 work (see below).
http://support.gateway.com/support/contact/chat.shtml
·3
Open your computer case using a Phillips screwdriver (or no screwdriver at all if you have a case that supports screwless entry).
Look in your operating manual for the location of the BIOS chip on the motherboard.
Remove this chip by gently wedging the screwdriver beneath it and prying it off the motherboard.
·4
Wait five minutes and place the chip back into position on the motherboard.
This will reset the memory, removing the password and allowing you access to your computer.
Nov 26, 2013 | Gateway LT Series LT4010U Intel Atom N2600...
My motherboard wont power on when i press the power button, all cabels ok, button ok, but still wont power on, sometimes after 10-80 pushes it powers up, need help, thanks...
please remove first the bios memory to reset your system if thats not fixed the problem try to remove the memory card and clean it with an eraser if it still not work, try to remove the video card and clean it also.
Aug 01, 2011 | Asrock K7VT4A-Pro Motherboard
Reset Bios Password
At command prompt type debug
you will get a - prompt where you can type the fallowing (<enter> means hit enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password crack - works 9.9 times out of ten
This is a password hack but it clears the BIOS such that the next time you start the PC, the CMOS does not ask for any password. Now if you are able to bring the DOS prompt up, then you will be able to change the BIOS setting to the default. To clear the CMOS do the following:
Get DOS prompt and type:
DEBUG hit enter
-o 70 2e hit enter
-o 71 ff hit enter
-q hit enter
exit hit enter
Restart the computer. It works on most versions of the AWARD BIOS.
Flashing BIOS via software
If you have access to the computer when it's turned on, you could try one of those programs that remove the password from the BIOS, by invalidating its memory.
However, it might happen you don't have one of those programs when you have access to the computer, so you'd better learn how to do manually what they do. You can reset the BIOS to its default values using the MS-DOS tool DEBUG (type DEBUG at the command prompt. You'd better do it in pure MS-DOS mode, not from a MS-DOS shell window in Windows). Once you are in the debug environment enter the following commands:
AMI/AWARD BIOS
O 70 17
O 71 17
Q
PHOENIX BIOS
O 70 FF
O 71 17
Q
GENERIC
Invalidates CMOS RAM.
Should work on all AT motherboards
(XT motherboards don't have CMOS)
O 70 2E
O 71 FF
Q
Note that the first letter is a "O" not the number "0". The numbers which follow are two bytes in hex format.
Using the jumpers
The canonical way to flash the BIOS via hardware is to plug, unplug, or switch a jumper on the motherboard (for "switching a jumper" I mean that you find a jumper that joins the central pin and a side pin of a group of three pins, you should then unplug the jumper and then plug it to the central pin and to the pin on the opposite side, so if the jumper is normally on position 1-2, you have to put it on position 2-3, or vice versa). This jumper is not always located near to the BIOS, but could be anywhere on the motherboard.
To find the correct jumper you should read the motherboard's manual.
Once you've located the correct jumper, switch it (or plug or unplug it, depending from what the manual says) while the computer is turned OFF. Wait a couple of seconds then put the jumper back to its original position. In some motherboards it may happen that the computer will automatically turn itself on, after flashing the BIOS. In this case, turn it off, and put the jumper back to its original position, then turn it on again. Other motherboards require you turn the computer on for a few seconds to flash the BIOS.
If you don't have the motherboard's manual, you'll have to "brute force" it... trying out all the jumpers. In this case, try first the isolated ones (not in a group), the ones near to the BIOS, and the ones you can switch (as I explained before). If all them fail, try all the others. However, you must modify the status of only one jumper per attempt, otherwise you could damage the motherboard (since you don't know what the jumper you modified is actually meant for). If the password request screen still appear, try another one.
If after flashing the BIOS, the computer won't boot when you turn it on, turn it off, and wait some seconds before to retry.
Jul 07, 2010 | Gateway NV5215u Notebook
COMPUTER THINKS IT IS OVER HEATING AND SUTS DOWN
try using it in a cooler place, clean out the air vents.
Turn on press f2 or f12 to access the bios and work your way through the bios looking for settings which set operating temperatures for fans etc. adjust as necessary. Beware though getting it wrong will fry pc.
Mar 21, 2010 | Gateway (4000274) Motherboard
My video card stopped working. i changed the video
maybe it is your motherboard, reset bios ... because you can see anything do as it follows , unlupg power coard-open case - pull out little silver battery- wait 10 sec-put it back in- switch power cord and start your computer.. that will reset your bios. cmos more exactlly... if you see the boot menu it is ok.. but if you can go to os.. then you must set you bios video output to pci... try and write back
Feb 20, 2010 | Gateway GM5260 PC Desktop
Hi, how can i reset BIOS password, notebook Gateway MT6705?
According to Gateway, there is no easy way to change the password. You need to contact Gateway Customer Services and ask for assistance.
Dec 17, 2009 | Gateway MT6705 Notebook
Cmospwd does not work in resetting the HDD (BIOS?) pwd for a Gateway Solo 1450 with a Phoenix 4.5 Bios. I cannot get into DOS without the password. I have also tried all the backdoor passwords and they do...
u may need to "FLASH" BIOS with a new firmware/software that goes into the BIOS chip, that will require a hardware engineer to do, else to reset BIOS you can try removing the COMS battery from the Motherboard and reinstalling it after 2 - 3 hrs, also in that time keep pressing the power switch of you PC for few minutes without the power supply and without the power cable attached to the PC.
Dec 06, 2009 | Gateway Solo 1450 Notebook
Son got into my bios and changed video setting from auto to int. Now I get a black screen, computer beeps like it's booting, I just cant see anything. Any ideas?
You need to reset your BIOS. To do this, you will need to open the side of your computer. Somewhere on the motherboard will be a jumper, possibly labeled clear cmos. There are three pins, usually with a cap on the first two. Remove the cap from 1-2 and put it on 2-3. Then, put it back again.
If you cannot find the jumper, then you can always remove the battery for a couple of hours. Put it back in again and your defaults will be loaded. You'll have to go in and set the time and stuff either way.
Jul 08, 2009 | Gateway Computers & Internet
Computers & Internet Logo
1,927 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
