Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
"close door" message
I have changed the door interlock switch but i'm still getting the message. Traced neutral cable from switch to the PCB behind the front facia panel. It looks like one of the components has popped. Could this be the problem and what is the PCB called? Thanks
  • ct66 Nov 11, 2008
    will not start as says close door - but door is firmly closed
  • veepers Dec 03, 2008
    My hotpoint wf325 won't work as it says the door is open, even though it is closed. this has happened before. Each time, after the machine has been moved. How can I persuade the machine that the door is in fact closed?
  • 43 Answers
This is a regular fault with these machines im looking at three of them its definatly the PCB nomally you will see a burt out track or something on the corner of the baord im afraid you will need to replace this part if you decide to do this mark all the plugs on the pcb with coulored felt tip pens to avoid putting them on the new board in the wrong place definatly worth repairing exellent machine
Posted on Nov 12, 2008
Pcb board
Possible causes:
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
SEE the steps before and fix it. God bless you
May 28, 2013 | Samsung Microwave Ovens
Microwave error message F7
This is for whirlpool models.Try this procedure and see if it helps.what is your model?
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Feb 11, 2013 | Microwave Ovens
My electrolux ewf 1030 get err 44 help me pls ?
E44 - It means "Door closure sensing circuit faulty".
Replace the circuit board and restart the diagnostic cycle to check further alarm condition.
When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5 on door interlock device, no.3 on electrical diagram) is powered by the triac (DOOR TY) on the PCB: after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed). The door interlock prevents aperture of the door while the appliance is in operation.
Microprocessor recognize closure position by sensing circuit connected to J2-1 on electronic board.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
electrolux-ewf-1030-get-qdylxco5jx0zjejqiwkxkzw5-1-0.jpg Dado
Aug 12, 2011 | Electrolux EW1200i Front Load Washer /...
MY microwave is giving me an error code F7 - call for service
This is all i could find on this error, Its alot to check. Microwave will not operate (cook). F7 error code
Possible reasons:
as needed.
the problem
blockage
inverter.
Jun 23, 2011 | Whirlpool GMH5205XVS Microwave Oven
Code f7 comes up on the timer won't run more than 30 sec
The following is pulled directly from this forum, where someone ran into a similar problem. I hope this is helpful:
Possible reasons:
as needed.
the problem
blockage
inverter.
Jun 17, 2011 | Whirlpool GMH5205XVB Microwave Oven
It always say F7
HI. This is, essentially, a inverter fault error cofe(F7). This code will indicate that there is an electrical circuit malfunction located at the L1 an neutral junction point on the main inverter board, itself. I will post a quick check point list below to guide you through the necessary troubleshooting that is needed at this time. If all check points below check out ok, simply replace the inverter board.
Check Points:
as needed.
3. Check the thermal fuse for the magnetron.
5. Unplug the oven for at least 40 seconds. If removing power for that length of time solves
the problem:
blockage
6. Verify that the control cable to the 1100 watt inverter
inverter.
8. If problem persists, replace the main control PCB.
Dec 02, 2010 | Whirlpool MH2155XP Microwave Oven
Error F7
Possible reasons:
as needed.
the problem
blockage
inverter.
Nov 18, 2009 | Whirlpool GH9176XMS 1100 Watts Microwave...
When i try to turn on the microwawe it flashes "door" and will not start. It appears to be sealing normaly
It sounds like the door sensing (primary interlock ) switch is bad. Sometimes, the contacts can get dirty and not close to zero ohms, telling the CPU that the door is closed. It could also be a loose or dirty connector at the switch or a loose ground. Then, possibly a bad control PCB.
Sep 14, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Hotpoint aquaruis extra WMA A34 WASHING MACHINE
hellooooooo
Well its either the door interlock or the pcb behind the control panel....
What sometimes happens is that the door lock will blow the the pcb obard if there is an electrical short and if so you will need to replace both..
however sometimes its just the door interlock..
if you need advice on how to get to it then let us know cheers
Jan 11, 2008 | Washing Machines
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
76 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
