Question about Westinghouse Dishwashers
Have a dishwasher model #MDB121RFM2, serial # 72945364 it doesnt work need to know when was made and sold so have an idea if i can still get parts
2 Suggested Answers
  • 7 Answers
SOURCE: How do I replace the door latch on my dishwasher?
Don't try to bend anything! The latch mechanism in the door is probably broken. Open the door and remove the 11 torx screws holding the inner panel on. You will probably find broken plastic bits on the pathetically flimsy latch; mine failed after 4 years and I expect it to happen again.
If you do, see the link given in "I Have 3 problems with my dishwasher, my...",
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168615&diagram_id=1349844#d1349844 Unlatch the two switches and slide them off the old part and onto the new one, observing all the obvious precautions about not getting shocked and putting the switchess on correctly. Reassemble the door and latch with the screws.
Posted on Nov 10, 2010
Whirlpool Gold Dishwasher- bowls in center of top rack are full of water, bowls in corners have almost no or no water in them and dishes on top rack are dirty. Dishes on bottom rack are clean.
First try running a cycle of "Dishwasher Magic". You can find this at Walmart for around 5 bucks. This will clean and condition the inside of the dishwasher and the inside of the pump and motor.
If this doesnt help...and the plastic and/or metal components in the dishwasher seem to look and feel intact..this would lead me to believe there is an issue with the pump and motor. These are sold as 1 unit or as seperate units depending on the model. Changing it is simple if you know how to dissconnect and reconnect a dishwasher. Take into consideration the age of the unit, the cost of the part, and the cost of a total replacement.
Oct 29, 2013 | Dishwashers
GE dishwasher leaking somewhere from bottom, what are common problem ares for this to occur?
There are o-ring seals around many pump motors where they install in the bottom of dishwashers. There are also shaft seals which separate the electric motor from the pump unit. In order to research your options you need to know the GE model number and often the serial number.
There are many web based parts search engines to find out what your parts might look like. If you will find the model number located on your unit, then Google GE appliance parts. You will be led to a number of sites which you can then view exploded parts diagrams of your unit, part numbers and usually prices. I try to get an idea of parts price range by looking at several sites and then call my local parts supplier to see how they compare. I buy a lot of parts on line. You can often purchase OEM parts from on line dealers at a savings compared to local brick and mortar sellers even including shipping.
Nov 10, 2012 | GE Dishwashers
I have a friend who has a Hot Point dishwasher, it will not drain, the model # is HDA2000205WH, The Serial # is TV797163
What most likely is causing what is the drain solonoid that attatches to the pump assambly is hanging up and not opening the flapper inside the pump asm. allowing the dishwasher to drain.Usually that solonid wont open the flapper because of leakage on the seal for the pump flapper that connects to that soloniod. this link http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Dishwasher-Parts/Model-HDA2000G02/1811/0130000/E2136729/00002?blt=06&prst=&shdMod= shows the solonoid asm. in item#s 413,418,426,493,494,497,&553 look at the drawing in the link to see what that solonoid looks like.If their is water leakage around that solonoin asm. the pump needs to replaced complete with that solonoid asm. If no leakage that solonoid could be replaced without having to replace the entire pump asm. The part# for that solonoid asm sold as a complete asm. is WD21X802 if the entire pump needs to be replaced due to leakage the part # is WD26X10013 they can be purchased from your local appliance parts store or online at
repairclinic.com
apdepot.com
assuredparts.com
I hope this helps,
Gene
Aug 04, 2011 | Hotpoint Dishwashers
I have a bosch dishwasher model classxx maxx freedom performance sgs43co2gb/35. the machine when turned on doesnt stop,so i checked the control panel and there was a black ring of soot,before i purchase a...
i think your model was part of the recall and the repair is free to fix call bosch and they will take of ity. they need to know the model asnd serial number to know if it is one of the recall
Mar 08, 2010 | Bosch Dishwashers
We have a Haier dishwasher and the capacitor burned out. The mahcines are sold at Argos and Comet but I can't source a replacment part which seems kind of crazy. It is out of Warranty and comet can't...
Make, model, serial number of your unit is ... ? I have dealt with capacitors for over 50 years, so I know what I'm doing. But there is no such thing as a five MICROVOLT capacitor, which is what 5uv means to a scientist like myself! Did you mean five micro FARAD, which should be expressed 5uF? But the voltage rating is critical, and the physical size is critical and the temperature rating is critical and the lead diameter is critical and the lead spacing is critical and the style (axial lead versus radial lead) is critical.
Apr 20, 2017 | Haier Dishwashers
I need a serial number for a CS2.. I tried the one posted on July 2009, but doesnt work!! any ideas??? I mean ...any numbers?????
Serial Number: 1045-1081-7168-0517-1621-7430
1045-1089-2721-6416-2385-9227
1045-1084-1031-8210-6515-4645
1045-1080-4977-7643-3129-8101
Do let me know if it works..
Cheers, Rajeish
Jul 11, 2009 | Adobe Photoshop CS2 for PC
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
G843SCVI Dishwasher
I am a authorized Miele Service tech - we can supply you with any parts you need - just give us a description and your model number / serial number
Thanks
mpservices@cox.net
Oct 26, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Machine washing
what did you nee to know???? check that model doesnt seem valid, whose the manufactue,
Feb 21, 2008 | Dishwashers
Dishwashers Logo
51 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
