Question about Kenmore 659 Electric Dryer
Wont start How do i access the thermal fuse?
Cant access the thermal fuse
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please provide your COMPLETE model number (located around the door opening), so that can verify how your dryer is configured. Different models require different methods of accessing the internal components and I want to make sure I give you accurate advice.
  • tom doyle Jul 16, 2013
    110.84182
  • Eddie
    Eddie Sep 02, 2014
    110.67032601
  • 943 Answers
HI if theres a bottom panel on you dryer. remove front panel. their is where the thermal fuse is located on the air duct. if you dont have a bottom panel. pull the dryer from wall. remove back panel. clean all dust in dryer and the venting. the thermal fuse is on the left, on the air duct. a small plastic piece, with 2 blue wires to it. replace this part. thanks the appliance doc.please rate my answer. thanks.
Posted on Oct 11, 2008
What does the thermal fuse look like on a kenmore elite dryer
the back panel to access this part. Be sure that you unplug the machine before starting. On certain machines, the thermal fuse is located in the front. To access this you must remove the kickplate, which can be done by pushing the clips, one on each side jsut above the top of the kickplate, in between the top and abottom portion. The part numbers are the same for either style dryer. To test this part you can either take the wires off it and tie them together then plug the machine back in and see if it heats, or you can use amultimeter and check to see if there is continuity, if there is its good, if not, bad. The thermal fuse will usually be white, and if located in the back, be thin and long with two wires on it, left and right. If in the bottom front, it will be front center on the exhaust duct.
Apr 28, 2012 | Kenmore Dryers
Last nite mid cycle my 90 series dryer quit and now i cant get it to do anything. changed the fuses in the fuse box but still nothing . might it be the thermal fuse ?
may be the thermal fuse but here is a website that can help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 10, 2011 | Kenmore Dryers
Dryer makes click when push start button but wont start
The problem is likely a blown thermal fuse. This thermal fuse is wired in series with the motor and if it blows, power to the motor is terminated and the motor cannot run. No dryer function works when the motor cannot run.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if the problem is not addressed above but indicate the exact model number of the machine for further advice.
Feb 01, 2011 | Kenmore Dryers
My dryer is a kenmore 110.61082000 and it wont start. it keeps displaying check lint screen even though it is completely clean and the sensor bar is clean. what is wrong?
The thermal fuse located on the blower housing is blown and since it is wired in series with the motor, power to the motor is terminated, the motor will not run and no dryer function works. Disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to expose the thermal fuse on the blower housing.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the thermistor if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards. Let us know if you need further advice.
Jan 30, 2011 | Kenmore Dryers
Lights turn on but dryer wont start
The problem is likely a blown thermal fuse. Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the front left bottom of the dryer cabinet if the dryer has the lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Jan 23, 2011 | Kenmore Dryers
Our Whirlpool dryer model #LER7646AQ0 will not start. Door switch checks for power with a power tester. Put new start switch in and still doesn't work. Do I need to use Ohm tester or will power tester...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Jan 11, 2011 | Dryers
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at...
Dec 30, 2010 | Whirlpool LER5636P Electric Dryer
Dryer wont start but the timer cliicks frigdiare dryer
It sounds like the thermal fuse. Without knowing model number I cant tell you exactly. Depending on how you access it. Near the blower housing you will see a little white sliver fuse ot a round fuse with two wires running to it. The one next to it has 4 wires running to it. Disconnect power before opening the dryer... Take a meter and see if it has continuity. If not its bad. Anything further please feel free to reply.
Jul 10, 2010 | Frigidaire GLER642A Electric Dryer
My 2006 kenmore elite dryer wont turn on
The F40 code indicates a communication problem between the main machine control and the blower motor control board. According to your symptoms, it is likely that this problem is being caused by a blown thermal fuse. I recommend the thermal fuse for continuity.
Unplug the dryer before accessing this component. Access this fuse and pull one wire off. Measure the resistance across the leads of the fuse using a volt/ohm meter. You should measure near zero ohms of resistance (continuity) if the fuse is good. If you measure infinite resistance (open), then the thermal fuse is blown and will need to be replaced.
NOTE: If the thermal fuse is blown, check for a restriction in the exhaust vent to the outside of your home. This type of problem will cause the fuse to blow.
You can order a new thermal fuse from the Sears PartsDirect website. The part number is 3390719.
This should fix your dryer problem.
Mar 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Wont turn o
Hi
check the thermal fuse that is small white Ceramic Fuse maybe that is defective.
Thanks
Dec 05, 2008 | iLO 3200 32 in. LCD Television
Kenmore 659 Electric Dryer Logo
124 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
