Question about Hisense TL2620 26 in. LCD Television
Hi Sense 26'' LCD2629 No Picture No Sound Just Black/White Lines
Have had TV for 2 months and everytime there is a power failure, the TV will not go back on. We try everything and after a couple of days it all of a sudden goes on ? Driving me mad !!
  • Karen Veldsman Sep 04, 2008
    Thank you SO much = it worked, was gonna take the TV back !!!
  • pratapkvda Sep 18, 2008
    its the same problem.My satellite receiver is connected to the a/v RCAmode.but the mode automatically switches to tv analog mode (antenna /Cable mode ) and starts searching every 2 minutes for no reason
    the next problem is Tv switches on , on its own , when its in standby mode .
    Could some body help on that ?
  • 71 Answers
Unplug the TV to let the memory clear. Wait 1 minute, replug, see if that works.
Posted on Sep 03, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Powers up - white picture with lines and no sound
Sounds like a min board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 14, 2014 | RCA L26HD35D TV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Vizio has sound but no picture.
Hello
The T'Con board [Timing Control Board] has damaged. This board can be located at the bottom side of the LCD panel. You have to open the tV, to take it out. There is no repair to this board, and only card basis replacement should be done. OK.
Feb 27, 2012 | Vizio VW32L 32 in. LCD HDTV
26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Mar 12, 2009 | Insignia LCDTV26 26 in. Television
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
Playstation2 conection to 26
i assume your using either a yellow/white/red or yellow/green/blue/white/red rca lead to plug in to your telly, make sure they are all going to the same input ie, input 1 or input 2 and the correct colours
Sep 02, 2008 | Televison & Video
Slow to come on, picture flashes black, 32" SONY tv
blankenship, the "IK circuit" is blanking your screen, only "fix" is temporary, remove back of tv, and on rear right side (facing into the back of the set) you can see 2 philips type plastic screws mounted on the flyback transformer, one is focus the other is screen, do not adjust focus , turn screen control clockwise slowly until you get white retrace lines on screen, then turn counterclockwise until retrace lines disappear, this increases drive from tube to IK circuit, will last anywhere from 6 months to 18 months and then it`s replacement time, questions? e-mail me back. good luck, BMW Rider
Jan 11, 2008 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Hisense TL2620 26 in. LCD Television Logo
700 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
