Question about Konica Minolta DiMAGE 5 Digital Camera
What is Automatic Sensitivity Gain? - Konica Minolta DiMAGE 5 Digital Camera
    Master:
  • 425 Answers
The Automatic Sensitivity Gain function amplifies the signal output from the CCD during processing. It increases the camera sensitivity and eases optimizing focus or makes the viewfinder easier to see to some extent. If the lighting conditions become darker beyond the capability of Automatic Sensitivity Gain, the Automatic Monitor Amplification is activated.
Posted on Sep 15, 2005
Stereo channels of Xenyx 1202 are very very quiet
It sounds as if the input is too low. what happens if you plug whatever is going into the stereo channels into a pair of mono channels. Or are you taking about the phono stereo tape input?
The stereo channels are line level whereas the other channels have both line and mic level inputs, what are you trying to put through the stereo channels? You must make sure the gain switch is set to the -10dB to get the most sensitivity (the mono channels have about -132dB max sensitivity BTW) You probably need a different mixer or possibly a submixer if you are needing more than 4 low level inputs.
May 06, 2014 | Behringer Music
Tip
Need For Speed Shift Keyboard tips
For anyone who uses keyboard in playing NFS Shift try one these settings.
Steering Dead Zone-15%
Accel Dead Zone-10%
Brake Dead Zone-10%
Steering sensitivity-5%
Acell Sensitivity -5%
Brake sensitivity-5%
Speed steering Sensitivity 100%
Steering Dead Zone: 50%
Accelerator Dead Zone: 25%
Brake Dead Zone: 5%
Clutch Dead Zone: 10%
Steering Sensitivity: 100%
Acceleration Sensitivity: 40%
Braking Sensitivity: 50%
Clutch Sensitivity: 40%
Speed Steering Sensitivity: 0%
Inverse Shifting: Off
Camera Y Axis: Normal
AI Difficulty: Medium
Handling Model: Normal
Steering Assist: Low
Braking Assist: Off
Anti-Lcok Brakes: On
Traction Control: Low
Stability Control: On
Damage Effects: Full
Gears: Automatic or Manual
At least anyone can now enjoy the game without having the hassle of wheels and other devices cluttering up their desk.
These settings work well in the new 1.02 Patch hope these helps.
on Dec 15, 2009 | Video Game Consoles & Games
Yaesu ft 1000d
Be sure the RF gain is turned up, if it is and there's still low RX sensitivity, it probably has lost the GASFET transistor in the front end.
Mar 11, 2014 | Radio Communications
Have to use rf gain control to control volume. no control or very little with af gain control. ft101ee
RF gain is not used to control volume. It's used to adjust the sensitivity of the radio. If you have a station nearby that's very strong that you wish to listen to, turning down the RF gain will help reduce distortion and/or interference. The control for Volume is "AF Gain" (Audio Frequency Gain). You want to use it to set the volume level.
Oct 15, 2013 | Radio Communications
What is the relation of lense maximum apertures and camera settings?
You have not stated which model camera body you have so I can only give you general Nikon information. There is a range over which the automatic settings will work for each camera. In addition, Nikon bodies have multiple sensitivity ranges. On the D90 for example, go into the "Shooting Menu" and open the "ISO sensitivity settings." You will see "maximum sensitivity" and "minimum shutter speed" menus along with the "ISO sensitivity auto control" options. Turn off the auto control option and manually set the maximum (ISO) sensitivity and minimum shutter speed. Also, the Shooting Menu also has "High ISO NR" settings that can be used to accommodate most lighting situations. You need to look in your camera's manual for all the details. The Nikon website has manuals available for all the Nikon products.
Sep 19, 2012 | Nikon D3, D40, D40X, D50, D60, D70, D80,...
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
I have to turn sound up to 48-49 to watch a movie and get good sound. Seems it should loud in the 20's.
Most movies are mixed at a much lower volume than CD's because there is a THX standard of 85dB which allows for greater headroom. The amount you have to turn up the gain on your amp is relative to the sensitivity of your speakers and the distance you are from them; every time you double the distance from your speaker you lose 6dB.
Most stock surround sound speakers have a lower sensitivity, meaning less SPL per watt/meter distance.
Jan 06, 2011 | Onkyo TX-DS575 Receiver
Garmin Fishfinder 160 will not display bottom contours and does not display depth continuously.
Change your setting from saltwater to fresh water even if you fish in sea water,your transducer is a 00/200KHZ and not a 50/200KHZ.
Good luck
Willem
Mar 01, 2009 | Garmin Fishfinder 160 GPS Receiver
Galaxy 2547
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Feb 01, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Raymarine depth finder freezes
What is the gain/sensitivity set too? if its 80-100% lower it. Does that model have a battery? If so pop the battery out and back in after changing the gain.
May 05, 2008 | Computers & Internet
Konica Minolta DiMAGE 5 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
