14 Inch LG with Video Cassette in hold won't even show a spark. Took cover off and checked fuse and ok but no signs of life.Power goes beyond fuse holder but nothing starts up! Help
This just about covers all the possibilities!!!
Thanks
Posted on Sep 05, 2008
    Scholar:
  • 141 Answers
Probably a blown diode, capacitor, or chip. Inspect the board for signs of a burnt out component. Should be in the vicinity of the high voltage AC section near the fuse holder.
Posted on Sep 03, 2008
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Nov 03, 2012 | 2002 Dodge Neon
Just bought a poulan 14 inch chainsaw...filled it with bar oil and the gas oil mix. Trying to start and won't even turn over. Any suggestions?
If it wont turn over, it may be because the cylinder is full of fuel, remove the spark plug under the top cover, with the plug out does it no crank over, if so give it a good few pulls to clear it out, replace the pluf and try again, using no choke and full throttle, just one point you didnt fill the fuel tank with oil by mistake??
Jul 18, 2011 | Poulan 14" Chainsaw
TV set appears to be 'dead'
Check the power supply capacitors to see if they are bulged.
If they are replace them, this should fix the problem, if not replace the main board.
otherwise replace the power pcb
May 23, 2010 | LG 26LH200C 26 in TV
Xbox showing no signs of life at ALL.
Hook up your power adapter to the wall and see if you get a green light, if you do then you know the power adapter is good. If you don't get a green light or you get an orange light then you know the ac adapter is bad and then get another one to hook up to the 360 and if you still don't get power then you know the main board inside of the 360 is bad.
Nov 30, 2009 | Microsoft Xbox 360 Console
Aiwa AV-D58 wont power on
this happened with mine two. all i did was press powert and enter at the same time and it clicked for like 2 hours or so and then it turned on. it was cool
Dec 09, 2007 | Aiwa AV-D58 Receiver
How to get the @ sign
You should just have to hold the shift key down and type the @
Aug 10, 2007 | Brother ML-100 Typewriter
Polaroid FLM 2011
have a tech repair your tv the problem is in the power supply and related circuit.good luck.
Apr 12, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
Top Televison & Video Experts
